Hello there :mellow: , Not sure which section to post in :unsure: , so yeah, I need help finding a better graphic card & CPU for my PC, the montherboard: IPMEL-AE (Evans),
it's not a custom build pc,this link is the model of my pc i have, this will show everything: HP Pavilion Slimline Spec's
https://linustechtips.com/topic/98362-hi-looking-for-help/
This should go in future builds/planning
edit:
Motherboard supports the following processor upgrades:
  • Intel Core 2 Quad (Yorkfield) series
  • Core 2 Duo E8xxx (Wolfdale) series
  • Core 2 Duo E7xxx (Wolfdale) series
  • Intel Pentium E5xxx with Dual Core Technology (Wolfdale) series
  • Celeron Dual Core E1xx0 (Conroe) series
  • Celeron 4xx (Conroe) series
Just save up and build your own, this computer will need a lot of upgrading because socket 775 is dead.  So, save up and build a custom PC
There are 10 types of people in this world, those who understand binary, and those who don't.
https://linustechtips.com/topic/98362-hi-looking-for-help/#findComment-1316150
What are planing to spend on the upgrade? what do you want to do with your computer?
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
https://linustechtips.com/topic/98362-hi-looking-for-help/#findComment-1316174
https://linustechtips.com/topic/98362-hi-looking-for-help/#findComment-1316391
wantted to get better graphic and CPU but it doesn't seem worth doing with this PC from other reply's, looks like I have to build a custom 1 & I'm a gamer.
You'll have to get a new case,PSU,CPU and GPU.
poops, I thought so  :(.
is it possible to get good enough custom build gaming pc with £250 budget? if not then £500..., I'm not very good at looking for the spec comparing which is better or worse & if it helps I play Starcraft 2 & MMORPG's.
https://linustechtips.com/topic/98362-hi-looking-for-help/#findComment-1322812
I'll whip you up a build ;)
https://linustechtips.com/topic/98362-hi-looking-for-help/#findComment-1322829
@Tist I think you will need an OS,I couldn't find any retail version of Windows which is pretty weird....This'll be an absolute epic machine for the price!
Plus you get BF4 with that graphics card which is a pretty sweet game right now and when they fix it it'll be even better.
@WoodenMarker Anything to add or change?
CPU:  AMD FX-8320 3.5GHz 8-Core Processor  (£109.31 @ Ebuyer)
Motherboard:  ASRock 990FX Extreme3 ATX AM3+/AM3 Motherboard  (£74.36 @ Amazon UK)
Memory:  Corsair XMS3 8GB (1 x 8GB) DDR3-1333 Memory  (£49.67 @ Amazon UK)
Video Card:  Asus Radeon R9 270 2GB Video Card  (£149.12 @ Scan.co.uk)
Case:  BitFenix Merc Beta (Black) ATX Mid Tower Case  (£29.99 @ Amazon UK)
Power Supply:  Fractal Design Integra R2 500W 80+ Bronze Certified ATX Power Supply  (£43.73 @ CCL Computers)
Operating System:  Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  (£72.59 @ Ebuyer)
Total: £528.77
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-01-07 02:26 GMT+0000)
https://linustechtips.com/topic/98362-hi-looking-for-help/#findComment-1322883
Other mmorpg's like what?
It depends on what the OP is doing. If he's not doing much heavy gaming and just playing games primarily like Starcraft 2, he could just go with an APU.
There's also no point getting the 270. the 7870 is £130.
https://linustechtips.com/topic/98362-hi-looking-for-help/#findComment-1322921
Yeah but just saying if he wants to mix it up and play a FPS with some problems,he has BF4 cause the card comes with BF4 and the difference is just 10Euros.
https://linustechtips.com/topic/98362-hi-looking-for-help/#findComment-1322960
At the moment i'm playing Atlantica online,lord of the ring online and later this year I'll be playing Elder scroll online,Not sure about Minecraft if it's a MMORPG though. I would like be able to run like 2game's atleast fine with good fps or possible more.
https://linustechtips.com/topic/98362-hi-looking-for-help/#findComment-1328891
You need to quote a post or tag a member or else they won't get a notification you replied to them.
I would just get a new system at that point.
This will do: http://uk.pcpartpicker.com/p/2xCdO
https://linustechtips.com/topic/98362-hi-looking-for-help/#findComment-1330076
Where's the graphic card?
i thought it be a intel CPU but is that better off?
https://linustechtips.com/topic/98362-hi-looking-for-help/#findComment-1335213
The system uses an APU so the graphics are integrated onto the cpu.
Going intel would cost more and require a graphics card for a decent gaming experience.
https://linustechtips.com/topic/98362-hi-looking-for-help/#findComment-1335250
Ok, Can I play those game's at a medium~high setting and play smooth still?
Yes other than for ESO--the game's not out yet.
https://linustechtips.com/topic/98362-hi-looking-for-help/#findComment-1335382
  • 1 month later...
