Graphics card limitations in case?
btng
If the case manual says that the graphics card limitation in terms of length is 300mm - how long graphics card is actually recommended in that case? Is there a general gap that is needed for air flow or can I get a GPU that is 299mm (hypothetically)?
it does not really matter that much in terms of airflow since if you hypothetically you have the said 299mm gpu in terms of performance pretty much the same
ASTRAY NOIR
CPU
Ryzen 5 3600
Cooler
Corsair H100I PRO
RAM
PNY XLR-8 EPIC-X DDR4-3200 CL16 32GB
GPU
ASUS ROG RTX 2070
STORAGE
SAMSUNG 850 EVO, 2xSEAGATE BARRACUDA PRO 1TB,A2000 1TB
Case
NZXT H500
PSU
Enermax Revolution DF 650W
MONITOR
MSI MAG272,LG 22MP68BQ,DELL D2015H
PERIPHIRALS
Ducky One 2 (HORIZON) || Glorious Model O- Pink || G305 || Razer Nari Essential || HyperX Cloud II
Yeah, you can get a 299mm GPU. Depending on the case, you can get a longer GPU and cut the HDD tray out (or 5.25" bay). If the case doesn't have one of those though, then yeah, it's a pretty hard limit. It might also not account for the 15mm or so thickness of a front fan
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
Is there a specific case and specific model of graphics card you are looking at? Might help us identify any issues you might have.
The case is the Fractal Design Meshify C TG. I am looking at 2080ti cards with triple fans. They are usually very long. I only have case fans in the front of the case and no radiator. According to the manual I can fit a card that is 315mm maximum (with a fan installed).
The listed dimension in this case is the maximum size the retailer guarantees that a component should fit. You MIGHT be able to squeeze in a card thats 316mm or longer (assuming you keep the fan), but it wouldn't be officially supported. For example, I managed to fit a 300mm long GPU (1080ti FTW3) into a Corsair 380T (290mm official GPU length) without modding the case, just moving the front I/O wires.  I've also fit a Enermax ETS-T40 (161.7mm) CPU cooler into a NZXT S340 Elite (161mm) which barely touched the glass.
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
Nice, but is it bad for airflow or anything else than the actual size limits?
Nope. Just a matter of if it will or wont work physically.
