Search In
  • More options...
Find results that contain...
Find results in...
Help with laptop desicion
Can someone help me find a laptop that is either used and cheap or for sale and cheap I would be using it for very minor gaming and mostly for homework.
How much are you willing to spend?
"May your frame rates be high and your temperatures low"
I misread titles/posts way too often--correct me if I don't.
I am willing to spend up to $350 very small budget preferably used laptop
1 minute ago, PacketMan said:
Then you might consider some GTX 1050 for minor gaming, an i5 7300HQ at least and 8GB minimum, you can take a look at those specs on your amazon site and see which ones match those specs
Edit: also, you sure will consider buying something with long battery life for school, right?
I have a decent gaming desktop I just need something for on the go
What do you mean by minor gaming?
as he said “on the go”
so so i assume stuff like minecraft or other small games that do not need wifi (considering most laptops don’t have portable wifi, at least none i’ve seen
✧・゚: *✧・゚:*  Quote for a reply  *:・゚✧*:・゚✧
✧・゚: *✧・゚:*   Ask for discord   *:・゚✧*:・゚✧
Divinty original sin 2 with my friends
I think what they meant was that they would play on it while they were our and about but not literally while moving.
 Share
