Hi there
I am building a NAS with 10gbe base-t for backups of large amounts of data at a single time. This server will have 3 clients max at any one time.
Would the following be ok. I understand that the spinning drives will not be able to transfer at 10gbe speeds, however i want this to be the only bottleneck.
both hdds will be in a single raid 1 and the ssds in a seperate raid. thus crating two shares.  I know that the hardware is on the old side but its pretty cheap and reliable.
Also have the a similar setup at home with standard gigabit network providing 120mb/s linux to widnows clients
CPU: i3 2120 or e3 1220l
COOLER: artic alpine 11
MOTHERBAORD: intel dq67ow
RAM: 8gb ddr3 1300mhz
NIC: cheapest 10gbe base-t at time of purchase probably melanox
HDD 1: seagate 15k sas drive 500gb
HDD 2: seagate 15k sas drive 500gb
SSD 1: samsung 1tb 960
SSD2: samsung 1tb 960
lemme know if the cpu is a bottleneck for 10gbe,
I will be using  lubuntu LTS  with samba.
Server 1:  CPU: i3 2100T  SSD: 840EVO MOBO: DQ67OW NIC: i340 -T4
Server 2:  CPU: Pentium D  MOBO: Dell Dimension 5150
Switch 1: Netgear GS108
Switch 2: Cisco 3500
https://linustechtips.com/topic/979202-help-10gbe-nas/
yes  i will have 1 10gbe port connected to a 10gbe switch and the second direct to a single client
thoughts on the i3 2120 cpu
https://linustechtips.com/topic/979202-help-10gbe-nas/#findComment-11820049
I'm not so sure that CPU can handle 10GBPS. If you're moving around massive amounts of data like that, I think a dual core cpu might be a bottleneck. If transferring large files around the network (im not exactly if its different if its over LAN) is anything like downloading or uploading data , you will have trouble even with gigabit, nevermind 10-gigabit. Im not 100% sure on this though so let someone else join in the discussion as well.
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
https://linustechtips.com/topic/979202-help-10gbe-nas/#findComment-11820054
1 minute ago, Rehmat said:
what about a xeon e3 1220l
Its identical core count, so it will be very similar performance. Also when you reply to people, make sure to @Rehmat them or to quote them, otherwise they will never receive a notification of your response unless they are sitting are the thread and waiting,
https://linustechtips.com/topic/979202-help-10gbe-nas/#findComment-11820071
Really toss these, thee slow, loud and power hungry. Just ge ta normal sata  hdd
Samba likes cpu, something like nfs or iscsi would be faster here.
https://linustechtips.com/topic/979202-help-10gbe-nas/#findComment-11820079
CPU: E3 1260L
HDD 1: seagate 7200 barracuda
HDD 2: seagate 7200 barracuda
what about this setup. the cpu is 4 cores 4 threads
also the barracudas will only be used for archiving data whilst the ssds will be used for live data
lemme know
https://linustechtips.com/topic/979202-help-10gbe-nas/#findComment-11820568
3 hours ago, Rehmat said:
E3 1260L
if you are transferring that much data i would recermend a more modern processor, a i7 from 2015 would beat the crap out of it and would be able to handle the workload for a longer period of time, thats what would be best as transferring that much data can be heavy on the CPU and without Remote Direct Memory Access (RDMA) on your networking card, your client and server, your CPU is going to be bound quite a bit
*Insert Witty Signature here*
System Config: https://au.pcpartpicker.com/list/Tncs9N
https://linustechtips.com/topic/979202-help-10gbe-nas/#findComment-11821216
Personally I would opt for a 1st gen Ryzen right now, purely for core count... and there are some good bargains to be had too, have seen a 1700 as low as £140-ish and an 1800x for around £170 IIRC... of course that depends on what else you need in system as pci-e lanes and such.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/979202-help-10gbe-nas/#findComment-11821350
@paddy-stone tbh the reason for going for this setup is that i have many of the required parts already left over from other projects  and this will mainly be used for experimentation and  backups of files and videos. Any where around 800 to 1000 mbs speed is good enough. Most of the time there will be only the single client and
https://linustechtips.com/topic/979202-help-10gbe-nas/#findComment-11822855
Ah I see, no worries... yeah in that case I'd just see how you get on and only upgrade to newer hardware if you really need the extra speed. Any chance an auto backup like freefilesync might make your life easier?
So it backs up as soon as it detects a file change I believe.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/979202-help-10gbe-nas/#findComment-11823858
