Why would u wanna overclock ur PC to do word processing and powerpoint?
MSI MAG X670E TOMAHAWK WIFI Motherboard, AMD Ryzen 9 7900X3D Desk-top Processor (12-core/24-thread, 140MB cache, up to 5.6 GHz max boost), CORSAIR VENGEANCE DDR5 RAM 32GB (2x16GB) 6000MHz CL30 AMD EXPO iCUE Compatible Computer Memory, Samsung 990 PRO NVMe M.2 SSD, 2 TB, PCIe 4.0, 7,450 MB/s read, 6,900 MB/s write, Internal SSD, 2 x Seagate BarraCuda 4 TB Internal Hard Drive HDD – 3.5 Inch SATA 6 Gb/s 5400 RPM 256 MB Cache for Computer Desktop PC Laptop (ST4000DM004), MSI MPG A1000G PCIE5 Power Supply Unit, UK Plug - 1000W, 80 Plus Gold Certified, Fully Modular ATX 3.0, PCIe 5.0 GPU, XILENCE XC982 LQ240PRO AIO COOLER, XFX Speedster MERC 310 AMD Radeon RX 7900 XT 20GB 1 x AOC CU34G2XE & 1 x Samsung U32J59XUQ 3840 x 2160 4K, 1 x Samsung Evo 970 Evo Plus NVME PCI-E 1TB, 1 x Samsung Evo 850 250GB, 1 X Sandisk Ultra II SSD 240GB + 2 X 4TB Seagate Barracuda SATA III,  MZHOU 7 Ports PCIe USB 3.0 Card,  2 x UGREEN Hard Drive Enclosure 3.5 inch External SATA Disk Caddy Reader USB 3.0 2.5 3.5 HDD SSD 16TB UASP Case Dock Station With 12V 2A Power Adapter For Windows with 6TB Seagate Barracuda SATA III, Fractal Design Pop XL Case + 4 Fractal Design 140mm Case Fans, Logitech MX Vertical & MX Ergo Trackball Mouse using same USB unifying device, Microsoft Ergonomic Keyboard, Windows 11 Pro x64 Retail, 6TB Seagate USB 3.0 Backup Plus Hub, Blue Yeti Microphone, Logitech C922 Pro HD,  Logitech C920 Pro HD, Bit Defender Total Security 2021.
Second PC (Cyclops) - MSI 990FXA Gaming, AMD FX 8370 4Ghz, Corsair 16GB Vengeance Red 9-9-9-24 1600Mhz, Arctic Cooling Freezer 13, Asus Strix 1050TI 4GB, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 1 x Samsung Evo 850 250GB, 2 X Seagate Barracuda 2TB, 1 X WD Black 2TB, 1 x ASUS 16x DVDRW, X-Case Eagle III Case, 3 X Corsair AF 120 Case Fans, EVGA 850 G2 80+ Gold + PSU, Logitech MX Master Mouse, Corsair K30 Keyboard, Logitech C920 Webcam, R0DE NT1-A Microphone, Scarlet 212 Audio Interface (Revision 2), Windows 10 Pro X64 Retail, Bit Defender Total Security 2021, 2TB Seagate Expansion USB Hard Drive.
Third PC (Old Trustie) - Acer Aspire M3400, OEM Mainboard, AMD FX Athlon II X3 425 2.7Ghz, 16GB Corsair Value 1600Mhz Ram, OEM CPU Cooler, AMD R7 260 2GB GPU, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 2TB Samsung SATA III, 1 X OEM 16X DVDRW, 1 X Acer OEM Case, 1 X Corsair AF120 Case Can, Corsair CX500 Bronze+ CPU, Logitech MX Master Mouse, Corsair K30 Keyboard, Windows 10 Home X64 OEM, Logitech C920 Webcam, Bit Defender Total Security 2021.
Printers Include - Canon MG5750, Canon, IP8750,  Canon Pixma Mega tank G5050 & 2 X Samsung Xpress C410W.
1 X Zexrow Xbox360 Wired Game Controller.
TP Link Archer AX6000 Cable Router Wifi6 with a Virgin Media Hub 4.0 in Modem only mode running 1GB Fibre internet.
Samsung Galaxy S21+ 256GB Mobile Phone.
Internet Speed.....
https://www.speedtest.net/result/9935039193
https://linustechtips.com/topic/978399-regarding-pc-build/#findComment-11811836
The ryzen 3 1300x has no onboard video.
so you have to get a gpu, something like a gt310 should be fine for display but a second hand gtx 750 (ti).
as for a motherboard, a good b350 with a nice vrm and heat sink should be fine, i would recommend the asrock b350 pro4m
Current build: Ryzen 7 1700x, asus prime x370-pro, 16gb gskill trident z rgb, asus rog strix gtx 1070 ti, corsair rm650x, nzxt s340 elite, samsung 840 pro 256gb, 1.5tb hdd.
https://linustechtips.com/topic/978399-regarding-pc-build/#findComment-11811838
2 minutes ago, homeap5 said:
For Office, Excel and Powerpoint ANY motherboard or processor will be good. Even old Core2Duo on LGA775. So if it's only for that - just buy cheapest components on the market. No OC needed. And any cheap SSD.
OK Thanks for your reply
which will be the best motherboard. and i want to use windows 10
https://linustechtips.com/topic/978399-regarding-pc-build/#findComment-11811848
Thanks for your reply sir
https://linustechtips.com/topic/978399-regarding-pc-build/#findComment-11811855
PCPartPicker part list: https://pcpartpicker.com/list/LLhmQZ
Price breakdown by merchant: https://pcpartpicker.com/list/LLhmQZ/by_merchant/
CPU: AMD - Ryzen 3 2200G 3.5GHz Quad-Core Processor  ($98.79 @ SuperBiiz)
Motherboard: Gigabyte - GA-AB350M-DS3H Micro ATX AM4 Motherboard  ($49.99 @ Amazon)
Memory: G.Skill - Aegis 8GB (1 x 8GB) DDR4-3000 Memory  ($57.99 @ Newegg)
Storage: Kingston - A400 240GB 2.5" Solid State Drive  ($38.99 @ Walmart)
Case: Thermaltake - Versa H17 MicroATX Mini Tower Case  ($24.99 @ Newegg)
Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply  ($22.98 @ Newegg)
Total: $293.73
Generated by PCPartPicker 2018-10-02 08:34 EDT-0400
https://linustechtips.com/topic/978399-regarding-pc-build/#findComment-11811913
CPU: Intel - Pentium Gold G5500 3.8GHz Dual-Core Processor  ($79.79 @ OutletPC)
Motherboard: Gigabyte - H310M A Micro ATX LGA1151 Motherboard  ($53.33 @ Newegg Business)
Memory: GeIL - EVO POTENZA 8GB (2 x 4GB) DDR4-2133 Memory  ($61.99 @ Newegg)
Storage: Inland - 240GB 2.5" Solid State Drive  ($37.99 @ Amazon)
Case: Rosewill - SRM-01 MicroATX Mini Tower Case  ($22.99 @ Amazon)
Power Supply: Corsair - Builder 500W 80+ Bronze Certified ATX Power Supply  ($23.99 @ Newegg)
Total: $280.08
Generated by PCPartPicker 2018-10-02 08:58 EDT-0400
Intel option.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
https://linustechtips.com/topic/978399-regarding-pc-build/#findComment-11811960
There's plenty of good reason to buy modern components as opposed to old ones, since maybe this PC ought to last a while.
replace the Athlon x4 with this Athlon 200GE:
https://www.grooves-inc.com/amd-gmbh-amd-athlon-200ge-2ghz-4mb-box-processor-amd-gmbh-hardware-electronic-pZZa1-2098639608.html?language=en&currency=USD&utm_source=froogle_us&utm_campaign=froogle_us&gclid=Cj0KCQjwrszdBRDWARIsAEEYhrfMC0V5AC3yxAEbkc4-v-TDPdK8bA_njeP3K8-eNfTuCN8YWljuff0aAl7VEALw_wcB.
An A320 motherboard would save some money over a B450 board, but you did request overclocking potential. Of course, none of the budget AMD CPUs can overclock, at least outside of Ryzen.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/978399-regarding-pc-build/#findComment-11811965
You all wants to put better and better components. I understand that every computer may be as good as possible and I know that on this forum even i7-8700K + 1070 is not enough for MS Paint. But COME ON! This one time guy needs something for using MS Office! This is exactly why AMD makes their cheapest processors and Intel makes Celerons! This is exactly great example that cheapest motherboards are made for someone! Please - made configurations as cheap as possible, so in the future, if this guy will want computer for games, he can buy second computer and no regret that he spend much money on this one. Cheapest motherboard, chepaest CPU (even Celeron), cheapest SSD, no HDD, 4 GB memory in one stick (more than enough for Office). And that's it!
https://linustechtips.com/topic/978399-regarding-pc-build/#findComment-11811980
Yeah That's basically what I did. (except motherboard, which could be $10 cheaper)
Primary PC:
PSU tier list
https://linustechtips.com/topic/978399-regarding-pc-build/#findComment-11811988
Here we see the three different levels of effort into posting a PC parts picker list.
Copy pasta
Copy pasta with links
Copy pasta with links and formatting
The only sub-tier here would be posting a screenshot xD
https://linustechtips.com/topic/978399-regarding-pc-build/#findComment-11812004
Total: $280.08
Intel option.
That rosewill case would be a nightmare to build in. Cheap construction, and the bulky look of the sides is hideous. Not really worth the savings IMO, especially not for long term use.
Primary PC:
PSU tier list
https://linustechtips.com/topic/978399-regarding-pc-build/#findComment-11812006
Just now, Ross Siggers said:
Here we see the three different ways to post a PC parts picker list.
Copy pasta
I love the new auto formatting tool
Primary PC:
PSU tier list
https://linustechtips.com/topic/978399-regarding-pc-build/#findComment-11812007
4 hours ago, VarunK said:
I want to build a PC only for work like MS Office,Excel,Powerpoint etc no gaming. AMD Ryzen 3 1300x will work ? Pls suggest me a Overclockable Motherboard for my CPU.
** NO Budget for Graphics Card **
Currently using Intel Pentinum e5700
Budget around $270.
If no budget for a video card, go for a Ryzen 2200g or 2400g processor. Or you could...…….Since you have an LGA775 motherboard and no gaming uses for your current rig, maybe you can save some $$$ by getting a used but high end Core 2 Quad  or Core 2 Duo and a new SSD to speed things up.
CPU: Sempron 2500+ / P4 2.8E / P4 2.6C / A64 x2 4000+ / E6420 / E8500 / i5-3470 / i7-3770
GPU: TNT2 M64 / Radeon 9000 / MX 440-SE / 7300GT / Radeon 4670 / GTS 250 / Radeon 7950 / 660 Ti
https://linustechtips.com/topic/978399-regarding-pc-build/#findComment-11812589
