is single-rail a problem in <600W PSUs
9 hours ago, 17030644 said:Can it cause damage to your PC if your system draws <600W
9 hours ago, schwellmo92 said:Completely depends on your PSU
9 hours ago, Comic_Sans_MS said:Depends on the PSU.
And that is what there is to say...
Depends on the circumstance, what we are talking about, what the isue is, how high the OCP is set, how thick the Cable is, how high the Amperage of the quasi short
9 hours ago, Comic_Sans_MS said:I would go multi rails if possible. You should never encounter a problem where you cannot draw enough power from one set of rails - you are likely doing something wrong if that's the case.
Yeah, absolutely because if the Manufacturer isn't lying with the PSU, you usually have OCP on all rails. And more protection is never a Problem, is it? ![]()
Single Rail is just easier for the manufacturer and also cheaper, because nobody has to think about the rail distribution, the OCP Set Points and you can use cheaper protection ICs...
