So yeah i need a gaming headset but im not sure if i want a wireless headset or not... any suggestion? pros and cons?
Corsair C70|i7 3930K|Corsair Vengeance 16GB 1600Mhz|Asrock x79 Extreme6|Samsung SSD 256GB|WD Green 3TB|Corsair H100i|Corsair TX750m |GTX 780 Palit Super JetStream (review here https://linustechtips.com/main/topic/54814-palit-gtx780-superjetstream-review/ )  -_-|
STILL LEARNING ENGLISH  :P  :P  :P
https://linustechtips.com/topic/97573-headset-wireless-or-not/
If you're just looking for a gaming headset I don't really know. There's not that much of an advantage to a wireless headset as you will be sitting at your desk when you're gaming anyways, and wireless headsets are waaaay more expensive than wired equivalents.
https://linustechtips.com/topic/97573-headset-wireless-or-not/#findComment-1304916
that's a good point...for 150$ what wired headset do you suggest?
https://linustechtips.com/topic/97573-headset-wireless-or-not/#findComment-1304929
well personally, i like to go the wireless way as you can go anywhere around the house without having to worry about wires.
if you do go for the wireless route, the Logitech G930 looks good.
Pretty much for the wired headsets, the Corsair 1500 is a good choice.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/97573-headset-wireless-or-not/#findComment-1304954
Wired - Pros
1) More options to choose from.
2) Better quality for the price you are paying (A.K.A bang for the buck).
3) Less interference.
Wireless - Pros
1) The freedom of being able to move around.
2) The "coolness" of having a wireless headset.
3) Less hassle with it in general (no wires in particular).
Wired - Cons
1) The hassle of cables. A pain in the arse for me :(
2) You can´t move around that much (not really a con for gaming, but all this is general).
3) (Can´t really come up with something else here :) )
Wireless - Cons
1) Much more interference will go hard on the quality.
2) Less options to choose from.
3) Not really needed when it comes to gaming.
Just some general cons and pros of the top of my head :) Personally I would not get a headset at all and just go the route of separate mic+headphone. Don´t really know any good options in that price range… :(
Tor
Corsair Obsidian 650D - Intel 4770K CPU - Gigabyte G1 Sniper 5 - ASUS GTX 780 Direct CU 2 - Kingston Beast Hyperx Beast 16 GB RAM -  Corsair AX 1200i PSU - Samsung EVO drive 750 GB - Corsair AF series 120mm fans - Corsair H100i - Razer Blackwidow Ultimate 2013 edition - Razer Ouroboros - Razer Manticor - Windows 7 - Beyerdynamic MMX 300
https://linustechtips.com/topic/97573-headset-wireless-or-not/#findComment-1304967
i see... have you had experience with either the g930 or the corsair 1500?
Wired - Pros
Wireless - Pros
Wired - Cons
Wireless - Cons
Thanks a lot for the pros and cons list, cleared out most of my doubts... let's say i wanna go mic+headphone what amount of money can get me a good setup?
https://linustechtips.com/topic/97573-headset-wireless-or-not/#findComment-1304979
See if you can get the Sennheiser PC360 at that price, it would actually be a good deal.
If not, proper headphones with a seperate microphone would be the best option. Take a look at the Sennheiser HD558 or the Audio-technica AD700x.
THE signature
https://linustechtips.com/topic/97573-headset-wireless-or-not/#findComment-1304991
For that money, I don't suggest a gaming headset at all. Buy yourself a nice pair of headphones and a desktop microphone to go along with them. Gaming headsets usually sound like crap in comparison. The only time you really need to care about them is if you're buying a wireless headset. In which case, there are a couple good options: the Corsair Vengeance 2100 and the Logitech G930. If not, then buy the microphone and headphones separately. You could look around for some good headphones, but I wouldn't recommend the Audio-Technica ATH-M50s for gaming because I've read too many complaints about them. An excellent microphone, however, would be a Blue Snowball. If that's a bit pricey and you want better headphones, just pick any microphone that sounds decent, and Google some "best headphones" lists. The V-Moda Crossfade LP, Grado SR80i, or Sony MDR-XB-whatevers are some good general recommendations for your budget.
Want to find parts in your budget? Logical Increments is the guide you need. | In the market for a headset? Read this thread. | If you're looking for headphones, please refer to this thread. | Stop being backhanded when offering advice.
CPU: Intel i7-3770K @ 3.5 GHz | CPU Cooler: Thermaltake Frio OCK | Motherboard: ASUS P8Z77-V LK | Memory: 16 GB Corsair Vengeance LP (DDR3-1600) | GPU: MSI Radeon HD 7870 GHz Edition x 2 (Crossfire) | Storage: 120 GB Kingston SSDNow V300 SSD, 2 TB Toshiba HDD | PSU: Corsair TX850 V2 | Case: In-Win Mana 136 (Black)
Monitor: ASUS VS248H-P | Keyboard: Corsair Vengeance K70 (Cherry MX Brown) | Mouse: Logitech G500 | Speakers: Logitech X-140 | Headphones: Philips Fidelio X1, Sony MDR-X05 | Webcam: Logitech C510
https://linustechtips.com/topic/97573-headset-wireless-or-not/#findComment-1305001
Well for 181.25 USD you can get this combo which will blow any headset in the same range out of the water :)
Audio Technica ATH-M50: http://www.amazon.com/Audio-Technica-ATH-M50-Professional-Monitor-Headphones/dp/B000ULAP4U/ref=sr_1_1?ie=UTF8&qid=1388845594&sr=8-1&keywords=ATH+M50
Blue Snowflake: http://www.amazon.com/Blue-Microphones-Snowflake-USB-Microphone/dp/B0012AUHXW/ref=sr_1_1?ie=UTF8&qid=1388845796&sr=8-1&keywords=Blue+Snowflake
There are other options as well, but this is not much over your aforementioned budget and will be a good combo (Plus that the M50s aren´t overly bass heavy while still packing bass so you will be able to listen to all different sorts of music genres and feel the explosions in game :) ).
Tor
https://linustechtips.com/topic/97573-headset-wireless-or-not/#findComment-1305023
There will always be bad reviews of headphones. The M50s have quite few bad ones actually… :)
Tor
https://linustechtips.com/topic/97573-headset-wireless-or-not/#findComment-1305029
No no no, in terms of quality, the ATH-M50s I could easily recommend. It's for gaming that I can't, because apparently they just don't sound good for it.
https://linustechtips.com/topic/97573-headset-wireless-or-not/#findComment-1305039
 uhm.. I've already seen the ath-m50 in quite a few videos... i tought those were studio headphones lol i really hope here in italy aren't overpriced :S
https://linustechtips.com/topic/97573-headset-wireless-or-not/#findComment-1305050
Not necessarily. Some people use them for studio use, but a lot of people use them for just listening to music. There's not that big a difference between the two, really; it's just about getting closer to hearing what the artist intended.
https://linustechtips.com/topic/97573-headset-wireless-or-not/#findComment-1305058
that's why i hate my country .-. the ath-m50 costs 150 euros on amazon.it :( its like 200 dollars without the mic D:
https://linustechtips.com/topic/97573-headset-wireless-or-not/#findComment-1305059
Oh shit :( Didn´t see that you were Italian :(
In that case I´ll have a look and see if I can come up with a new suggestion for you :) What is then your maximum budget in Euros?
Tor
https://linustechtips.com/topic/97573-headset-wireless-or-not/#findComment-1305087
i can wait a few days and spend max 150/180 euros for the combo... i know it's a bit low as budget but i will have a motorcycle to maintain in the near future
https://linustechtips.com/topic/97573-headset-wireless-or-not/#findComment-1305124
Just a little problem… I don´t understand anything of your site :( And the prices are wild… A Snowflake for 121 Euros...
Tor
https://linustechtips.com/topic/97573-headset-wireless-or-not/#findComment-1305141
lol didn't think of that :P thanks a lot anyway for the good advices to you and the other members! You cleared out most of my doubts concerning this topic! and yes prices are very very wild in italy... let's say my friend from usa want to ship a videocard as a gift from his local shop it would cost me 22 plus 5 percent of the value for that card just to pass the border... just insane how italy works...
https://linustechtips.com/topic/97573-headset-wireless-or-not/#findComment-1305196
i've had experiences with the G930 itself, seeing as my brother has it. and it's actually not a bad headset, the comfort on it is absolutely spot on, the gaming experience with it is amazing, you can hear every sound. and the 7.1 surround sound helps too.
Old Rig
https://linustechtips.com/topic/97573-headset-wireless-or-not/#findComment-1305387
A quick look brings me to the Sennheiser HD558 and the Zalman ZM-MIC1. I have experience with the microphone (and it's pretty good for the money) and listened to the HD558 in a store and was pleasantly suprised. Also this combo is not that overpriced compared to other places.
THE signature
https://linustechtips.com/topic/97573-headset-wireless-or-not/#findComment-1305718
For the cheapest good option, the Pioneer SE-A1000 is only 78 euros. Just take my word that it sounds great and is comfortable, but I can understand if you're leaning towards the 558 since you tried it in-store and it's good as well.
I just searched microphone on Amazon.it and these came up at the top of the list with good reviews - http://www.amazon.it/Trust-16973-Starzz-Microphone/dp/B003MFYY3Y/ref=sr_1_1?ie=UTF8&qid=1388858157&sr=8-1&keywords=microphone http://www.amazon.it/Trust-TRUST-MC-1200-Microphone/dp/B000185ALA/ref=sr_1_2?ie=UTF8&qid=1388858157&sr=8-2&keywords=microphone - not clip-ons like the Zalman, however.
https://linustechtips.com/topic/97573-headset-wireless-or-not/#findComment-1306253
