Help finding a new power supply?
Solved by Stefan Payne,
1 hour ago, sakamoto747 said:I read a couple of reviews of the two power supplies I was considering.
X) be quiet! Pure Power 10 CM 500W 2) BitFenix Whisper M 80 Plus Gold Full Modular 450W PSU
Between those two, the Whisper M. Although the be quiet is a bit quieter, the Whisper M is without a doubt the better unit.
Well, as long as you don't pair it with an MSI 1080ti....
Between the two there should be a gap of only 15€ and for that, I'd get the Bitfenix. The Pure Power only makes sense w/o CM.
