SSD ONLY boots with hard drive plugged in?
Luke
So this is a weird one. I built a PC for a friend and have a 240GB SSD and a 1TB HDD but i decided to remove the HDD and now the SSD will not boot alone for some reason. I get the "Reboot and select proper Boot Device" message when only the SSD is installed but when the HDD is installed as a secondary drive it works fine. I'm 100% sure that Windows is installed on the SSD and i've tried different SATA ports, SATA cables and SATA power cables but this problem seems to persist. Any ideas? I have the strong feeling that if i installed Windows with only the SSD installed it wouldn't be causing this issue when i remove/add other drives.
Intel i7 3770K [] Asrock Z77 Extreme 4 [] MSI R9 290X 4GB [] 16GB  G.SKILL 2133Mhz [] Crucial MX100 256GB [] WD Black 1TB [] XFX Pro 850W [] Fractal Define R3 [] Func MS-3 R2 [] Corsair K60 []
Try reinstalling Windows again without the HDD attached.
Maybe the UEFI/Windows Boot Manager was installed elsewhere.
So You Wanna Be A Playa, But Your Rig's Ain't Fly,
You Gotta Hit Us Up, To Get A Pimped Out Rig,
You've Got To Pimp My Riggggggg...  (DAMN RIGHT)
This happened to me once. The Windows boot manager got installed on the second drive instead of on the same drive as the OS.
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
This happens when you install windows on the SSD without unplugging the hard drive.
The only fix is to reinstall windows, and this time make sure ONLY the SSD is plugged in.
windows has this amazing tendency to put the bootloader in places where you dont want it.
its why i always recommend you install windows with nothing plugged in but the media you're installing from, and the media you're installing to.
you can move the bootloader, but it is actually more work than just to reinstall windows.
