Here's what I'd change:
- Get an air cooler like the Dark Rock 4 instead of an AIO liquid cooler
- Buy an ASUS Strix Z370-E motherboard instead of a MSI motherboard
- Buy a modular PSU like a EVGA G2 650W or a Corsair RM650x
- Don't buy Windows from Microsoft's site, get it from Kinguin for a lower price
- Buy a 2TB Seagate Barracuda HDD instead of a 1TB one, it costs only a bit more but gives you double the capacity
- Try to get faster RAM with a lower CL, the
My PC building tips:
- Watch Linus' video on PC building tips
- Don't panic if your PC doesn't boot up the first time
Here's the build I put together for you: https://pcpartpicker.com/list/qxfYRJ
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/967746-my-first-pc/#findComment-11712971
What do you mean by faster than I thought less MHz better
https://linustechtips.com/topic/967746-my-first-pc/#findComment-11713153
More MHz is better. Less CL is better.
https://linustechtips.com/topic/967746-my-first-pc/#findComment-11713249
4 hours ago, ParrrotPee said:
So I'll have a new, first gaming PC but I don't know much about pc's, can you guys pls help. I also want RGB so much like linus ( maybe a little less) but still, here's my proposition. Also some begginer building PC tips appreciated
https://pcpartpicker.com/list/yGHkHh
the build is alright, but the MSI board is overpriced.
https://linustechtips.com/topic/967746-my-first-pc/#findComment-11713473
why asus? MSI is perfectly fine Ive be rocking a msi z87-gd65 since 2013 havent had any problems (well until now but thats because its getting older)
Desktop:ryzen 5 3600 | MSI b45m bazooka | EVGA 650w Icoolermaster masterbox nr400 |16 gb ddr4  corsiar lpx| Gigabyte Aorus GTX 1070ti |500GB SSD+2TB SSHD, 2tb seagate barracuda [OS/games/mass storage] | HpZR240w 1440p led logitech g502 proteus spectrum| Coolermaster quick fire pro cherry mx  brown |
https://linustechtips.com/topic/967746-my-first-pc/#findComment-11713485
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  ($339.99 @ Amazon)
CPU Cooler: EVGA - CLC 280 113.5 CFM Liquid CPU Cooler  ($104.89 @ OutletPC)
Motherboard: Gigabyte - Z370 AORUS Gaming 5 (rev. 1.0) ATX LGA1151 Motherboard  ($179.99 @ Newegg)
Memory: Team - T-Force Delta RGB 16GB (2 x 8GB) DDR4-3000 Memory  ($149.99 @ Newegg)
Storage: Samsung - 860 Evo 500GB 2.5" Solid State Drive  ($89.00 @ Amazon)
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  ($42.89 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1080 Ti 11GB AORUS Video Card  ($659.89 @ OutletPC)
Case: Corsair - Crystal 460X RGB White ATX Mid Tower Case  ($139.99 @ Amazon)
Power Supply: SeaSonic - FOCUS Gold 750W 80+ Gold Certified Semi-Modular ATX Power Supply  ($64.99 @ Newegg)
Operating System: Microsoft - Windows 10 Home OEM 64-bit  ($94.89 @ OutletPC)
Case Fan: Corsair - SP120 RGB 3-Pack w/Controller 52.0 CFM  120mm Fans  ($61.87 @ OutletPC)
Monitor: Acer - Predator XB241YU 23.8" 2560x1440 165Hz Monitor  ($399.99 @ B&H)
Keyboard: G.Skill - Ripjaws KM570 RGB Wired Gaming Keyboard  ($88.21 @ Newegg)
Mouse: Kingston - HyperX Pulsefire Surge Wired Optical Mouse  ($69.99 @ Amazon)
Other: Hyperx XL mouse pad ($29.99)
Total: $2516.56
Generated by PCPartPicker 2018-09-02 22:14 EDT-0400
https://linustechtips.com/topic/967746-my-first-pc/#findComment-11713506
Hey. Good build you have there. But since you seem to give importance to aesthetics, I've made some minor changes with your build.
Notes:
*Changed Motherboard and GPU. I chose the Krait and the Titanium GPU because they blend well together aesthetically. More so that you're getting a GPU riser.
*Don't worry about the GPU downgrade. The 1070 Ti is almost as good as the 1080.
*Changed the storage configuration to NVME + 2TB vs SATA SSD + 1TB
CPU Cooler: Corsair - H100i PRO 75.0 CFM Liquid CPU Cooler  ($115.01 @ Newegg)
Motherboard: MSI - Z370 KRAIT GAMING ATX LGA1151 Motherboard  ($133.98 @ Newegg)
Memory: Corsair - Vengeance RGB Pro 16GB (2 x 8GB) DDR4-2666 Memory  ($159.99 @ Amazon)
Storage: ADATA - XPG  512GB M.2-2280 Solid State Drive  ($103.89 @ OutletPC)
Storage: Hitachi - Ultrastar 7K3000 2TB 3.5" 7200RPM Internal Hard Drive  ($53.95 @ Newegg Marketplace)
Video Card: MSI - GeForce GTX 1070 Ti 8GB Titanium Video Card  ($469.99 @ B&H)
Power Supply: Corsair - TXM Gold 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($74.88 @ OutletPC)
Case Fan: Corsair - ML120 PRO RGB (3 pack w/Lighting Node PRO) 47.3 CFM  120mm Fans  ($98.56 @ Newegg)
Monitor: MSI - Optix G27C2 27.0" 1920x1080 144Hz Monitor  ($269.99 @ Walmart)
Keyboard: Kingston - HyperX Alloy Elite RGB Wired Gaming Keyboard  ($139.99 @ Amazon)
Other: Lightning node pro ($39.99)
Other: VGA xard holder ($40.76)
Total: $2375.83
Generated by PCPartPicker 2018-09-02 23:46 EDT-0400
https://linustechtips.com/topic/967746-my-first-pc/#findComment-11713686
4 minutes ago, ParrrotPee said:
Country?
Does it have to do anything but gaming, or do you just want more options in general?
ATX or ITX(Small/Tiny)?
https://linustechtips.com/topic/967746-my-first-pc/#findComment-11727493
Just now, meme smurf said:
for 2500$ you can build a great system! ill be taking a look on newegg creating a list of parts.
Might not be from the US my dude.
https://linustechtips.com/topic/967746-my-first-pc/#findComment-11727516
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  ($345.99 @ Amazon)
CPU Cooler: Cooler Master - MasterLiquid ML240R RGB 66.7 CFM Liquid CPU Cooler  ($119.99 @ Amazon)
Motherboard: Asus - ROG STRIX Z370-E GAMING ATX LGA1151 Motherboard  ($198.98 @ Amazon)
Memory: Team - Night Hawk RGB 16GB (2 x 8GB) DDR4-3200 Memory  ($154.99 @ Newegg)
Storage: Crucial - MX500 500GB 2.5" Solid State Drive  ($98.89 @ OutletPC)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($59.49 @ SuperBiiz)
Video Card: EVGA - GeForce GTX 1080 Ti 11GB SC2 Video Card  ($729.99 @ B&H)
Case: Cooler Master - MasterCase H500P Mesh White ATX Mid Tower Case  ($149.99 @ Amazon)
Power Supply: SeaSonic - FOCUS Plus Gold 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($69.99 @ Newegg)
Monitor: Dell - S2716DG 27.0" 2560x1440 144Hz Monitor  ($445.98 @ Amazon)
Total: $2374.28
Generated by PCPartPicker 2018-09-06 21:37 EDT-0400
Not sure if I went tooo overkill on the RGB. If it's too much you could totally save some money on a few things, such as the case and cooler.
I'm also not a big KB/M guru, so I'd rather leave those recommendations to other people. As for Windows, you could pay the full $100 but if you're fine with it you can get a questionably-legal $30 key from somewhere like kinguin, or just use windows without a product key (there's just a few customization limitations and a watermark, though I know you can get rid of the watermark).
Also, I left the GPU as a temporary replacement. The RTX 2080 and 2080 ti should be out in around 2 weeks, and I'd expect the 2080 to be a similar price but better performance wise. At the very least, it should drop 1080 ti prices. I would recommend waiting until then at the very least... If you're willing to, Intel has new CPUs planned for this quarter though we're unsure exactly when they'll drop.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/967746-my-first-pc/#findComment-11727544
I doubt he is. Don't know many people in North America that put the dollar sign after the amount.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/967746-my-first-pc/#findComment-11727551
1 minute ago, ParrrotPee said:
Yes I'm us and I prefer atx I'll probably stream or do video editing soon
Do you want a gaming focused system?
or a more overkill streaming system where you can just upgrade to a higher end GPU and better monitors later?
https://linustechtips.com/topic/967746-my-first-pc/#findComment-11727578
19 minutes ago, meme smurf said:
as for the watercooler i would go with a corsair h115i pro because people seem to like them, high quality cooler from what i can tell. not rgb but you can always stick some rgb fans on it xD
Yeah solid cooler, main reason I chose the one I did was RGB :D
20 minutes ago, meme smurf said:
for motherboard i would reccomend you go for the aorus z370 gaming 7 insted its myl motherboard for my main desktop and i love it. has plenty of rgb. cant argue with the rest of the parts tho. if you want even more rgb take a look at these fans
Also chose the Z370-E because it's Asus Aura compatible. I'm not sure how wide the Gigabyte ecosystem goes as far as cases and coolers.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/967746-my-first-pc/#findComment-11727599
CPU: AMD - Ryzen 7 2700 3.2GHz 8-Core Processor  ($279.99 @ Amazon)
CPU Cooler: EVGA - CLC 280 113.5 CFM Liquid CPU Cooler  ($99.99 @ Amazon)
Motherboard: MSI - X470 GAMING PRO CARBON ATX AM4 Motherboard  ($159.99 @ B&H)
Storage: Samsung - 860 Evo 500GB 2.5" Solid State Drive  ($99.99 @ Amazon)
Storage: Toshiba - P300 2TB 3.5" 7200RPM Internal Hard Drive  ($56.49 @ OutletPC)
Video Card: MSI - GeForce GTX 1080 Ti 11GB GAMING X Video Card  ($704.99 @ B&H)
Case: Cooler Master - MasterCase H500 ATX Mid Tower Case  ($106.90 @ Newegg Business)
Power Supply: Corsair - TXM Gold 750W 80+ Gold Certified Semi-Modular ATX Power Supply  ($86.90 @ OutletPC)
Operating System: Microsoft - Windows 10 Home OEM 64-bit  ($98.99 @ Amazon)
Monitor: Dell - S2716DG 27.0" 2560x1440 144Hz Monitor  ($444.48 @ Amazon)
Keyboard: Corsair - K66 Wired Gaming Keyboard  ($64.01 @ Amazon)
Mouse: Logitech - G502 Proteus Spectrum Wired Optical Mouse  ($49.98 @ Amazon)
Other: Phanteks RGB LED 4 Pin Adapter, Specified for Phanteks Cases with RGB  ($2.80 @ Amazon)
Other: Phanteks PH-FF120RGBP Halos RGB Fan Frame – High density LEDs, RGB,  ($10.12 @ Amazon)
Total: $2440.85
Generated by PCPartPicker 2018-09-06 22:45 EDT-0400
https://linustechtips.com/topic/967746-my-first-pc/#findComment-11727641
9 minutes ago, Herman Mcpootis said:
2 1080p monitors is going to be more useful for streaming. Could just do one at 120hz the other at 60hz.
https://linustechtips.com/topic/967746-my-first-pc/#findComment-11727664
Build something like this...
I hv added a 2 tb HDD and a better looking case..
Also .I have added in a gtx 1080ti and a 1440p 144hz monitor..
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  ($345.99 @ Walmart)
CPU Cooler: be quiet! - Dark Rock 4 CPU Cooler  ($74.90 @ Amazon)
Motherboard: ASRock - Z370 Extreme4 ATX LGA1151 Motherboard  ($158.98 @ Newegg)
Memory: Corsair - Vengeance RGB 16GB (2 x 8GB) DDR4-3000 Memory  ($149.99 @ Amazon)
Video Card: MSI - GeForce GTX 1080 Ti 11GB DUKE OC Video Card  ($599.99 @ Newegg)
Case: Thermaltake -  View 71 TG RGB ATX Full Tower Case  ($139.99 @ Newegg)
Power Supply: EVGA - SuperNOVA G3 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($89.72 @ OutletPC)
Monitor: Acer - XG270HU 27.0" 2560x1440 144Hz Monitor  ($348.88 @ OutletPC)
Keyboard: Corsair - STRAFE RGB Wired Gaming Keyboard  ($89.99 @ Amazon)
Total: $2302.78
Generated by PCPartPicker 2018-09-07 06:59 EDT-0400
https://linustechtips.com/topic/967746-my-first-pc/#findComment-11728466
I don't know if anyone's said this yet, but a GTX 1080 is overkill for a 1080p 144Hz monitor.
Intel i7 8700k | Asus ROG Strix Z370-I | NVidia RTX 2070 Super Reference | Corsair Vengeance Pro RGB 3600MHz x 32GB | Samsung 970 Evo 500GB NVMe | Samsung QVO 1TB SSD | Custom Loop | Corsair RMx 850w Gold | Phanteks Evolv iTX TG (modded) | Acer Predator XB1
https://linustechtips.com/topic/967746-my-first-pc/#findComment-11728658
I think gaming for now and then I'll change something
Then just an R7 2700 will be fine for streaming.
blowing a bunch of your budget on things that don't matter.
Should get one 1440p 144hz IPS display + 1080p IPS display, might have to run the 144hz at 120hz for windows to like both.
You don't have to buy windows you can install it for free using their media creation tool.
just buy this cheap keyboard/mouse kit that comes with likely bad but functional back up audio as well.
https://www.amazon.com/Mechanical-Keyboard-Microphone-Redragon-Switches/dp/B06ZYH9WB5/ref=sr_1_4?ie=UTF8&qid=1525560837&sr=8-4&keywords=Redragon
Vertical GPU mounts are usually bad for thermals depending on how close to the side panel the GPU gets.
Wouldn't spend $100 on fans...
anyways saved about $500
PCPartPicker part list: https://pcpartpicker.com/list/fvkWmq
Price breakdown by merchant: https://pcpartpicker.com/list/fvkWmq/by_merchant/
Motherboard: Gigabyte - X470 AORUS ULTRA GAMING ATX AM4 Motherboard  ($128.99 @ Amazon)
Memory: G.Skill - Aegis 16GB (2 x 8GB) DDR4-3000 Memory  ($135.98 @ Newegg)
Storage: Western Digital - Blue 500GB M.2-2280 Solid State Drive  ($94.99 @ Amazon)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($43.90 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1080 8GB D5X Video Card  ($429.99 @ Newegg)
Power Supply: SeaSonic - FOCUS Gold 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($74.99 @ Newegg)
Monitor: Asus - VS229H-P 21.5" 1920x1080 Monitor  ($95.49 @ Amazon)
Monitor: Nixeus - NX-EDG27 27.0" 2560x1440 144Hz Monitor  ($432.08 @ Amazon)
Total: $1823.30
Generated by PCPartPicker 2018-09-07 13:13 EDT-0400
https://linustechtips.com/topic/967746-my-first-pc/#findComment-11729471
3 minutes ago, ParrrotPee said:
I would like to have it mega rgb
Both of those high-end systems are virtually equal in terms of performance. So, I will not be able to tell you which to choose.
However, if you check my guide in my signature below - you will be able to choose the RGB Eco-system of your liking.
For best value I'd pick Enermax and for best customizability, I'd choose Corsair (iCue has endless customization potential as you can mix different lighting functions together & choose their timing/frequency and intensity)
Be free to ask me any question if you need (quote me), I will do my best to help you :)
Good luck
RGB & Fan control ULTIMATE GUIDE !
https://linustechtips.com/topic/967746-my-first-pc/#findComment-11735635
the not thermaltake one
Builds:
https://linustechtips.com/topic/967746-my-first-pc/#findComment-11735680
It looks like you're choosing between aesthetics. One is a mostly white and black build. The other is a mostly black build.
I have a...subtle disdain for Thermaltake...but I'll leave that out of the equation.
Personally I think the white and black build will look better disregarding the RGB because it's more interesting than black, but the black build has better RGB (to me).
Your call. Nice rigs you have planned, and good luck with it all.
https://linustechtips.com/topic/967746-my-first-pc/#findComment-11735705
