CPU i7 8700 97 degree problem
Go to solution Solved by Enderman,
Was the cooler used too or just the CPU?
Because you need to reapply thermal paste if it was used.
I have bought a 2nd hand CPU i7 8700, and upon checking the CPU temperature on speecy, core temp and even in my bios the temperature was so very high,
It always shown 97-98 degree. I personally touch the  backplate and yes it was too hot. I already checked in the bios if the processor was over clocked but it is still in 3.2 ghz
The details of my board is:
Processor - i7 8700
Motherboard - Z370 HD3P
CPU COOLOER - STACK INTEL FAN
Is there anyone solved same issue as mine?
Thank s
https://linustechtips.com/topic/967445-cpu-i7-8700-97-degree-problem/
Not surprised, that stock cooler is rubbish
Desktop benching:
Processor - i7 8700
Thank s
Since it's used, what Thermal Paste did u use between the cooler and the cpu?
So You Wanna Be A Playa, But Your Rig's Ain't Fly,
You Gotta Hit Us Up, To Get A Pimped Out Rig,
You've Got To Pimp My Riggggggg...  (DAMN RIGHT)
Reseat cooler with new paste. Or if you need to go shopping, consider getting budget cooler for it. i7 in heavy use can get hot, even non-K ones.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
It is now has low temparature, i just put thermal paste and fitted the stack fan. And also ive seen that it was O.C to 4.2 ghz haha
I just returned it
Thank you all
