Posted August 15, 2018 I finally set up my system at home with several computers. When i was using my router i only got 100mbit connection transfer speed. (up to 12mb per second) Now ive installed a 24port gigabit switch from planet and networking and the speed is appalling. I bought brand new Cat6 SFTP cables for everything and my transfer speed is not even 1mb per second >.< Ive checked both pc's that im transferring between and both have win 10 and state "1000/1000 mbps link speed.. Description: Intel(R) Ethernet Connection (2) I218-V Status: Operational Maximum transmission unit: 1500 Link speed (Receive/Transmit): 1000/1000 (Mbps) DHCP enabled: Yes Network name: Network Network category: Private Connectivity (IPv4/IPv6): Connected to Internet / Connected to unknown network any clue what this can be ? Link to comment https://linustechtips.com/topic/960475-extremely-low-transfer-speed-on-lan/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 15, 2018 Are you copying one large file or multiple small ones. Also can you send your network topography? Basically your network setup. Magical Pineapples
