30 fps and 60 fps
Some1iscool
Yeah, you can tell the difference between 30 and 60. 30 FPS is wack and choppy, while 60 FPS is smooth like a butter knife just slice through the butter.
30 FPS looks like hot garbage. LIterally unplayable. 60 FPS is very nice and smooth
First Computer: 3440x1440 @75Hz ROG STRIX 1080 Ti Core i5 8600K @ 1.415V @ 5.08 GHz Corsair Spec 02 EVGA CLC 280mm
30fps is minimum 60fps is standart i recomend 60 fps for fps shooters and fast action games
Naw, if this were true, consoles would have terrible sales.
30 FPS is fine in single player games, the input delay does not really change gameplay.
60 FPS is the minimum for online competitive games because the delay introduced by low FPS can be the difference between winning and losing.
For multiplayer fast paced/shooter games, I would actually recommend just about anything higher than 60fps.
"If a Lobster is a fish because it moves by jumping, then a kangaroo is a bird" - Admiral Paulo de Castro Moreira da Silva
"There is nothing more difficult than fixing something that isn't all the way broken yet." - Author Unknown
Intel Core i7-3960X @ 4.6 GHz - Asus P9X79WS/IPMI - 12GB DDR3-1600 quad-channel - EVGA GTX 1080ti SC - Fractal Design Define R5 - 500GB Crucial MX200 - NH-D15 - Logitech G710+ - Mionix Naos 7000 - Sennheiser PC350 w/Topping VX-1
Just now, App4that said:
1080p, 1440, and 4k.
4K is not pushing 60 FPS in the mainstream, sorry to kill your idea of the future. xD
THE HUMAN EYE CAN ONLY SEE 1FPS. HIT THAT LIKE BUTTON IF YOU AGREE!!!!!!!!!!!!
/s
important figure in mensa
It will soon buddy :). Technology is getting better each day as long we get our asses up.
nani
4k 60 is easy, even a console can do it now. 4k 144hz is a little tricky though
If anyone asks you never saw me.
nani
No, consoles can not do 4k 60.  They do 1080p/60 and upscale.  If a game is natively 4k it usually has super simple graphics.
No, the One X does native 4k 60fps. Not in all games, but in a lot of the MS titles.
Even a 980ti can lock 4k 60 in most titles with some settings changes that are next to imposible to pick up in gameplay, a 1080ti locks 4k 60 in just about any title without settings sacrifices.
Again, what year is it? How far back did I go?
Yes, easily! Hell, ever since I went 75hz I don't even like looking at 60. And it's not imagination, to make sure I wasn't just crazy I had someone switch between 60 FPS, 75 and 45 FPS randomly and I could easily pick out each without any hesitation. They could also pick it out just as quick.
i7 2600k @ 5GHz 1.49v - EVGA GTX 1070 ACX 3.0 - 16GB DDR3 2000MHz Corsair Vengence
Asus p8z77-v lk - 480GB Samsung 870 EVO w/ W10 LTSC - 2x1TB HDD storage - 240GB SATA SSD w/ W7 - EVGA 650w 80+G G2
3x 1080p 60hz Viewsonic LCDs, 1 glorious Dell CRT running at anywhere from 60hz to 120hz
Model M w/ Soarer's adapter - Logitch g502 - Audio-Techinca M20X - Cambridge SoundWorks speakers w/ woofer
my 1080 ti spits out around 2 fps & i'm never going back. Gameplay so smooth you wouldn't believe it
30 and 60 are very noticeable.  30 used to be serviceable, hell even 20 used to be 2 decades ago.  Frame pacing seems like the bigger issue IMO, and I've yet to have a PC that didn't illustrate that.  In that regard, consoles have always been superior.
No?
PC has better framepacing than console as a rule in general.
39 minutes ago, VegetableStu said:
that'd probably backfire if the monitor only runs on 15hz, LOL
*Fixed
normally I play games at 60... the one time I saw 120 it was so much better...
I should get a 120hz monitor one of these days...
