144hz monitor for my build
Arcana
Hello guys, im currently using 1366x768 monitor 60hz, and i want to buy 1080p monitor 144hz, do you think its worth to buy 144hz with this build? dont ask me to build different because i already ordered the cpu mobo and ram the rest i already have, i always playing Dota 2, CSGO, and PUBG do you guys think i can get 144fps? to use the 144hz with these set up? specially dota 2 and pubg
Specs:
CPU: i5-8400
Cooler: Stock Cooler
MOBO: Gigabyte B360M D3H
RAM: Vengeance LPX 2x8gb DDR4 C16 2666MHz
GPU:Gigabyte GTX 970 G1 Gaming
SSD: 60GB KINGMAXX (OS)
HDD: 1TB Seagate SSHD ST1000DX001
PSU: Seasonic M12-II 520 Evo
Case: NZXT Phantom Full Tower
If I were you I would buy a 1080p/1440p 144/165 24/27' gsync,
Just think how can a monitor last, (maybe 2 to 3 full computers)
I know people playing 1440p with a 960 @ dota2 without problems.
With your 970 dont worry you will have gpu for a few years and you allways can buy a newer when the time comes
I think best value
If you live in USA : Amazon.com-> Dell s2716dg (450$)
If you live in europe: Amazon.com-> omen 27(500€)
You can buy 1080p 24 inch gsync but is worse bang for buck. those 2 are a sweet spot 165hz 1440p gsync tn panels.
Case: Corsair 760T  |  Psu: Evga  650w p2 | Cpu-Cooler : Noctua Nh-d15 | Cpu : 8600k  | Gpu: Gygabyte 1070 g1 | Ram: 2x8gb Gskill Trident-Z 3000mhz |  Mobo : Aorus GA-Z370 Gaming K3 | Storage : Ocz 120gb sata ssd , sandisk 480gb ssd , wd 1gb hdd | Keyboard : Corsair k95 rgb plat. | Mouse : Razer deathadder elite | Monitor: Dell s2417DG (1440p 165hz gsync) & a crappy hp 24' ips 1080p | Audio: Schiit stack + Akg k712pro + Blue yeti.
Specs:
CPU: i5-8400
I think 120hz should work just fine
I think best value
my budget is only the cheapest 144hz 1080p i can get, i live in PH, can i still use 144hz even my fps doesnt reached 144fps?
Yes, but for best experience I allways recommend gsync or freesync, I dont care to play at 80fps or a 70-90 , but I cant play now without gsync, gsync outputs your hz to the fps making almost near 0 stutters.
There was an acer predator 1080p 180hz on the cheap (300-350$) with gsync
Edit: look on your country for this model , https://www.amazon.com/Acer-Predator-XB241H-bmipr-1920x1080/dp/B01C05C1OK
Your computer should be able to play all e-sport game at 144 fps just fine, except PUBG you need to put low setting if you want 144 fps. If you're really low on budget, then get either Asus VG248QE or BenQ XL2411. both are good budget 144hz monitor.
Primary PC
CPU: AMD Ryzen 7 3700X | M/B: Asus ROG Strix X370-F | RAM: G.Skill TridentZ RGB 3200MHz 32GB | GPU: Asus TUF RTX 3070 8GB GDDR6 | SSD: Samsung 960 Evo 250GB | HDD: Seagate Barracuda 4TB x2 | Power: Thermaltake Toughpower 80+ Gold 650W | Sound card: Creative Sound BlasterX AE-5  | Case: NZXT H500 | Cooling: NZXT Kraken X62 | Display: Samsung CHG70 27" 1440p 144Hz QLED
Secondary PC
CPU: AMD Ryzen 5 5600 | M/B: Asrock B450M Pro 4 | RAM: Kingston HyperX Predator 3200MHz 16GB | GPU: Asrock RX 5700 8GB GDDR6 | SSD: Crucial P1 1TB | HDD: WD Black 1TB | Power: Coolermaster Masterwatt 550 | CaseAerocool Cylon Mini | Cooling: BeQuiet Pure Rock Slim 2 | Display: Samsung CFG73 24" 1080p 144Hz QLED
Thanks for reading
thank you ill take a look a it!
what's the difference between the BenQ XL2411 and the BenQ XL2411Z?
they look the same to me.
Primary PC
Secondary PC
Thanks for reading
