hi so... i made a new pc build... but it wont power on
echy
im guessing because i might have the pc cables connected in the wrong place maybe?
It's really not possible to offer you any help without more information. Specs? A few pictures of the wires? What do you think you did wrong?
Main Rig:-
Server:-
Yeah gonna need a lot more information; do you get any beeps? Do any lights turn on? Do you get any fan spin? Does your motherboard show post codes?
no no beeping... no lights turn on
Could you post pictures?
Main Rig - Case: Corsair 200R   Motherboard: Gigabyte GA-Z270-GAMING-K3  CPU: Intel i5 7600 RAM: Corsair H55 RAM: Corsair Vengeance 16GB 3000MHz SSD: Crucial MX500 1 TB
HDD: 2TB WD Green  GPU: Gigabyte GTX 1660 Ti 6GB Windforce  PSU: Corsair CX 600W
HTPC - Case: CiT MTX-007B   Motherboard: Biostar H61MGV3, CPU: Intel i5 2400  RAM: Patriot 4GB 1333MHz SSD: 240GB Toshiba SSD PSU: 180W CIT (Came with case)
Corsair 200R Front Bezel Mod
this is my psu https://www.newegg.com/Product/Product.aspx?Item=N82E16817438014
this is my motherboard https://www.newegg.com/Product/Product.aspx?Item=N82E16813132986
Well there's your problem... You need to plug in the 20pin connector from the PSU into the motherboard.
The cable is the big one that's hanging off the computer case. The connector is to the right of the RAM.
I'd start with plugging in the power connector for the mainboard ;)
Judging by that you thought that the ssd plugs into the psu, i would stop building the pc right now before you damage it, and instead try to watch a pc building tutorial.
But right now it seems you forgot to connect the 8pin and 24pin motherboard power cables.
Please read the motherboard manual or watch a tutorial.
I see another problem: the power supply. Such a low tier PSU and non modular too, not even semi. Get a CX750M or something.
There are 10 types of people in this world. Those that understand binary and those that don't.
Current Rig (Dominator II): 8GB Corsair Vengeance LPX DDR4 3133 C15, AMD Ryzen 3 1200 at 4GHz, Coolermaster MasterLiquid Lite 120, ASRock B450M Pro4, AMD R9 280X, 120GB TCSunBow SSD, 3TB Seagate ST3000DM001-9YN166 HSD, Corsair CX750M Grey Label, Windows 10 Pro, 2x CoolerMaster MasterFan Pro 120, Thermaltake Versa H18 Tempered Glass.
Previous Rig (Black Magic): 8GB DDR3 1600, AMD FX6300 OC'd to 4.5GHz, Zalman CNPS5X Performa, Asus M5A78L-M PLUS /USB3, GTX 950 SC (former, it blew my PCIe lane so now on mobo graphics which is Radeon HD 3000 Series), 1TB Samsung Spinpoint F3 7200RPM HDD, 3TB Seagate ST3000DM001-9YN166 HDD (secondary), Corsair CX750M, Windows 8.1 Pro, 2x 120mm Red LED fans, Deepcool SMARTER case
My secondary rig (The Oldie): 4GB DDR2 800, Intel Core 2 Duo E8400 @ 3GHz, Stock Dell Cooler, Foxconn 0RY007, AMD Radeon HD 5450, 250GB Samsung Spinpoint 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management. UPDATE: SPECS UPGRADED DUE TO CASEMOD, 8GB DDR2 800, AMD Phenom X4 9650, Zalman CNPS5X Performa, Biostar GF8200C M2+, AMD Radeon HD 7450 GDDR5 edition, Samsung Spinpoint 250GB 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management and support for non Dell boards.
Retired/Dead Rigs: The OG (retired) (First ever PC I used at 3 years old back in 2005) Current Specs: 2GB DDR2, Pentium M 770 @ 2.13GHz, 60GB IDE laptop HDD, ZorinOS 12 Ultimate x86. Originally 512mb DDR2, Pentium M 740 @ 1.73GHzm 60GB IDE laptop HDD and single boot XP Pro. The Craptop (dead), 2gb DDR3, Celeron n2840 @ 2.1GHz, 50GB eMMC chip, Windows 10 Pro. Nightrider (dead and cannibalized for Dominator II): Ryzen 3 1200, Gigabyte A320M HD2, 8GB DDR4, XFX Ghost Core Radeon HD 7770, 1TB Samsung Spinpoint F3 (2010), 3TB Seagate Barracuda, Corsair CX750M Green, Deepcool SMARTER, Windows 10 Home.
Why would he waste money on that? The PSU he has there is just fine.
Where do you see an SSD on the pictures? They usually do have a 15-pin SATA connector, and thus need to be connected to the PSU, except it's an M.2 in which case I wonder how you would plug those into a PSU.
He's referring to a different thread by the same OP in which he was asking about how to connect a PSU to a SATA SSD.
You're funny. That PSU he has there is a tier 5 PSU, closer to the hazard side than it is to good. At least something like a CX750M is tier 4 and in terms of being a hazard or being good it's medium. Personally had a CX750M for a while now, heavy use in a quad socket server and now retired to my normal rig, hasn't let me down. That EVGA pile of garbage won't last half as long as a CXM PSU.
1st of all 750W is *WAAAAY* overpowered for that build or most other gaming rigs you see around except those running SLI. You can expect that EVGA PSU to have solid build quality. It does exactly what the CXM750W would do - supply the computer with power. There is literally no real-world advantage of swapping that PSU with the one you mentioned. If OP has excess money he'd be way better of investing that into another stick of RAM, than in an oversized PSU.
That PSU has FAR worse build quality than a CX750M. Also the op's build's power draw is 749W, meaning he is 1 watt under the max load for a CX750M and 149W  over the load of his PSU that he currently has. Do you realise how dangerous this is? Yes a CX750M has pretty much the exact amount of power that the computer needs, but at least it isn't OVERLOADED like his current PSU.
To the OP: Your computer won't power up because you're overloading the PSU. Get a PSU that is AT LEAST 750W or greater. I can help you with that.
Miscalculated your power draw, read my last post.
I would recommend this PSU for you, 250W above what you need but its better than having a PSU that is overloaded or maxed out:
https://uk.pcpartpicker.com/product/Vq38TW/corsair-power-supply-cp9020094na
While I don't believe that the CX750M buildquality is "far" superior I'm not argueing about relative build quality here. All I'm sayiong is that the OPs PSU build quality is way more than good enough.
That build's power draw is not even remotely close to 750W it is not even scratching the 500W mark. So no it is not dangerous.
Are you stupid? 1080 is 180W power draw EACH at full load and they have TWO OF THEM IN SLI. That is 360W in supply just for his graphics cards.  Recalculated his power draw anyway, turns out I went for 1080tis by mistake before, they're still over the 500W threshold (569W total power draw) and is pretty much touching the 600W limit of their PSU. A 750W PSU would be MUCH safer for them since it gives more headroom for any hardware upgrades (*cough* such as the 1080ti *cough*). Also a question for you: Do you have a multimeter at home? If the answer's no (which it probably is), then how the hell can you say that the EVGA PSU is of an acceptable build quality? These people who make and update the PSU tier list HAVE a multimeter and various electronic testing equipment and the results they get from testing a power supply on that equipment determines its tier in the list. In the EVGA PSU's case, I can safely say that it is NOT a good quality PSU.
Dude calm down and peel your eyes. That is NOT an SLI build there is a single 1080 in there. You can use a 450W PSU for that and still be good.
Well either way its a shit PSU. Garbage build quality, low down on tier list. It's a hazard. End of story.
It is a decent PSU now matter how much you love your CX750M. If you like it that much get one yourself and stop wasting other peoples money and time for no benefit.
I agree with xriqn. There is soo much more to a psu than output rating. Protection circuits for a start (over volt, short circuit, etc..), ripple suppression,voltage regulation. Poor ripple suppression to within 50% of within spec (so for 12v rail spec is +/- 120mV) so a ripple of 60mV constantly can reduce lifetime of parts signifigantly. The closer you get to that spec limit, the more it can affect your parts and stability. Most low end psu will have poor qualiry protection circuits or complete lack of them all together. I have seen low tier psu's from name brands with ripple of above 50% of range of spec.
Yes but the OPs PSU is not a poor quality one, it offers good protection and also is overpowered by far for this build. This pretty much says it all:
