PSU for 1080ti Mini ITX
LDX
Remember this video on the 380T???
Well I got it, and I am planning to put in there
a Ryzen 2700x + 1080Ti Gigabyte OC
I need a small PSU, not rectangular
cause im planning to install a couple HDD
I was thinking on the Corsair CX750 vs the TX750
But dont know which is better my guess is the TX cause is more pricy?
Suggestions pls Im going out shopping tomorrow morning
It (The Graphite 380T) supports full sized power supplies, so you're fine. I love the EVGA G2/G3 series of power supplies, they're great quality for a reasonable price.
27 minutes ago, LDX said:
Just get one of the 600W SFX units people make? Think Silverstone has one.
Otherwise Focus Plus Gold from Seasonic all day
I know, but there is a bracket for 2 HDD that doesnt fit in, if u pick that size of PSU
Looks like silverstone is not really expensive as Im seeing now at my local retailer
If you mean it's a decent price that's nice
they're usually pretty expensive because it's low volume and the component cost is likely high.
Really though that case is a bit large for ITX, coulda just gotten like a Q300L.
perhaps this is a low profile series, about 60 bucks
https://articulo.mercadolibre.com.pe/MPE-431707338-fuente-silverstone-essential-series-600w-80-pluswh-oferta-_JM
No idea, this is their STX model, probably an older one at this point
You sure? Some builds on PCPartPicker have that size of PSU installed with the HDD cage as well.
This build used an EVGA GS 650W.
https://pcpartpicker.com/b/vXyXsY
That's not an SFX PSU. That's an ultra low end ATX PSU. He was probably referring to the SX600-G, this one.
https://www.silverstonetek.com/product.php?area=en&pid=524
yap
that cage is for thinner HDDs and only one there is another cage for two thicker HDD
 but i will try it anyway
i already have a corsair RM850
so will see
G2 is fine, the G3 suffers with its OPP and OTP protections. Not recommended.
AX1600i owner. https://docs.google.com/spreadsheets/d/1_GMev0EwK37J3zZL98zIqF-OSBuHlFEHmrc_SPuYsjs/edit?usp=sharing My WIP Power Supply Guide.
I built in this case about a month ago. PSU's under 160mm long will fit without much fuss, and you can keep the 3.5" HDD tray. Just make sure you plug in all your cables into the PSU (if it's modular) before you install it.
20180707_154014.thumb.jpg.4a91fa6c9fd22b82b973ff7c401ada61.jpg20180707_154001.thumb.jpg.27f0ced7818e74204a78e4f60f43711c.jpg20180707_195603.thumb.jpg.5be64e50b1de2dce32b77e8eb8ae0c9d.jpg
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
G3 750W got a 9.8 from JonnyGuru, and he found no major issues with it.
How exactly does it "suffer" with its OPP and OTP protections?
To be fair, JonnyGuru himself doesnt do the reviews anymore.
Newer reviews have come out citing certain concerns with those protections.
https://www.tomshardware.com/reviews/evga-supernova-650-g3-psu,5533-6.html
should I get a seasonic platinum for this build?
it is much more expensive
but what am i getting?
Dude!!!!
tell me about ur build, how well does the 380t deals with the heat?
^^^ Just got an EVGA 550W G3 for $80 for my 2700X + 980 Ti rig and it's dope. Not a bad price for the quality PSUs they are either.
Main PC
CPU: i9 7980XE @4.5GHz/1.22v/-2 AVX offset
Cooler: EKWB Supremacy Block - custom loop w/360mm +280mm rads
Motherboard: EVGA X299 Dark
RAM:4x8GB HyperX Predator DDR4 @3200Mhz CL16
GPU: Nvidia FE 2060 Super/Corsair HydroX 2070 FE block
Storage:  1TB MP34 + 1TB 970 Evo + 500GB Atom30 + 250GB 960 Evo
Optical Drives: LG WH14NS40
PSU: EVGA 1600W T2
Case & Fans: Corsair 750D Airflow - 3x Noctua iPPC NF-F12 + 4x Noctua iPPC NF-A14 PWM
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 2020 M1 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch
I cant find evga g3 here in my country
41 minutes ago, LDX said:
Dude!!!!
Well I put a 200mm fan in the front, and that's basically it for case fans. No rear or side fans needed. Though my system is a bit less power hungry than yours. I went from a full sized ATX tower with 3 200mm fans to this mITX with just the single 200 in the front, and temps on both the CPU (4790k @4.4ghz) and GPU (970 FTW) are about the same even though I quote "downgraded" the CPU cooler.
The build itself is pretty straight forward, there's a lot of leftover cables since the distance from PSU to GPU and mobo are significantly shorter, but theres still plenty of room to stash cables under the CPU/Fan bracket on the Right side (which is why it looks so clean from the left). Keep in mind if you're going to use an AIO, you're limited to a 240mm RAD max size.
so will see
I've built a couple of these, and to elaborate on what @TVwazhere mentioned, if you plan on using a PSU longer than 160mm with the HDD cage, you'll need a 380T PSU extension bracket which is available online.  It extends the mounting point about 20mm past the back of the case.
https://www.corsair.com/us/en/Categories/Products/Accessories-|-Parts/PC-Components/Cases/Graphite-Series™-380T-PSU-Bracket/p/CC-8930296
Looking for more details about a product, or experiencing technical issues?  Visit our support page below, and one of our Technical Support staff can help you out:
https://support.corsair.com/
9 hours ago, LDX said:
The CSM is a mediocre PSU. Not recommended.
