Fans for nzxt h500
Solved by WoodenMarker,
On 7/27/2018 at 9:34 AM, jevjev said:corsair LL series are good you can get them in plain or rgb and you can get a 3 pack with controller
LL's are a waste of money if lighting isn't a priority. There are fans that perform similarly or better at a lower price.
On 7/27/2018 at 9:38 AM, szym3k said:What if I was to install a 240mm radiator at the front, how would it impact the airflow?
It would substantially reduce the intake but allow fresh air for the rad. It can be compensated for with higher fan speeds.
If you're getting an AIO, the included fans should perform fine. Otherwise, the most appropriate fans would depend on the rad you're using.
