help MSI 730 is not working. Help!
35 minutes ago, PG_DCMINI06 said:my msi 730 is not working. Idk if this is just with with mine but there is no pci e slot on the card. You might think "probably need new drivers" but my PC start up for about an hour then it shuts off. If it helps my PC has a and fx 4300 and 8gb of ram 2x4. My PC is a pre built.
I’m not sure what no PCIe slot means..... it seems like you have a farely old system so it’s probably overheating in an hour. I would replace the thermal paste on your GPU and CPU and then see if that fixes the problem. If not it is likely a bad PSU or failing RAM. It could also be a corrupted OS or failing drive but I don’t think that’s the case based on what you are saying. Does your case have good cooling. One simple but effective trick to improve cooling on bad air flow cases is just to rip off the side panel. Good luck.
