need help please :o
Go to solution Solved by jiyeon,
1 minute ago, jevjev said:
i will go with your list due to it being slightly cheaper and having bulk storage that will help with my media/photoshop work and game storage thank you so much for helping i can finally start buying my pc parts :) is there any tips you would recommend when building and when it posts :P
Final thing, you might want to consider that MSI Frozr cooler if you have the budget, it's a pretty rad cooler that matches the theme quite well. :)
I recommending getting to know the NZXT S340 Elite because there's all sorts of things in the S340 Elite that you have to know when building inside it, such as the PSU bracket and the bottom drive cage. In addition to that, the NZXT Aer fans are controlled through NZXT Cam as far as I'm aware, so that's how you'll control the RGB on them once you've done the build.
Happy building, be sure to update us on when you've built your brand new PC! :D
going with the blue and white theme what sleeved cables shoud i get
The blue and white cables for sure, going with straight white would be too much since you already have a white GPU, white case, and white memory.
Blue and white cables balances out the build them more. :)
mechanical keyboard switches aficionado & hi-fi audio enthusiast
switch reviews  how i lube mx-style keyboard switches
Just now, seoz said:
LLs are RGB
yeah they are :P
Arctic frost
my first build
cpu: intel i5 8600k
cpu cooler: ARCTIC - Freezer 33 eSports ONE
motherboard: Asus ROG strix z370-E
ram: Corsair - Vengeance LPX 16GB (4 x 4GB) DDR4-2133
ssd: Kingston - A400 240GB 2.5" Solid State Drive
hdd: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
gpu: Asus - GeForce GTX 1060 6GB Dual Series
case: NZXT - S340 Elite (White)
psu: EVGA - B3 550W 80+ Bronze
thanks to @seoz for helping make the list :P and its based of her custom rig
ok sounds like a plan :D
Arctic frost
my first build
cpu: intel i5 8600k
Arctic frost
my first build
cpu: intel i5 8600k
4 minutes ago, jevjev said:
-snip-
Are you on Cablemod's website? You might want to check out their LED lighting strips, if you want to light up your build. The Z370-E has 2x 4 pin RGB and 1x 3 pin addressable RGB headers. Allowing for more lighting.
4 minutes ago, seoz said:
I'm pretty sure LLs are RGB. Going with LLs for front would still retain the RGB glow though as appose to going with SW3 or Noctuas for front where it would just seem like an unlit abyss.
Yeah, the LLs are definitely very RGB. The most RGB fans on the market, imo. Wouldn't an RGB strip give more RGB per buck, though?
i was planning on adding rgb strips but didn't list them :P
Arctic frost
my first build
cpu: intel i5 8600k
I'm personally not a fan of RGB strips, I like a more permanent solution hence LED/RGB fans, at least for the inside of my PC.
3 minutes ago, jevjev said:
I love it! It's going to be beautiful once it's all built, the S340 Elite is a fabulous case choice. :) Good luck when it comes to building it, I'll be here if you need help. :D
you wouldn't like my room then :P i have to much rgb
my room rgb list:
tv led strips
desk led strips
rgb keyboard
rgb mouse
rgb headset
rgb lightbuld
yeahhh not my fault though i got given it all for xmas
Arctic frost
my first build
cpu: intel i5 8600k
thanks :D ill make sure to tag you in the build blog :P
Arctic frost
my first build
cpu: intel i5 8600k
