need help please :o
1 minute ago, jevjev said:i will go with your list due to it being slightly cheaper and having bulk storage that will help with my media/photoshop work and game storage thank you so much for helping i can finally start buying my pc parts
is there any tips you would recommend when building and when it posts
Final thing, you might want to consider that MSI Frozr cooler if you have the budget, it's a pretty rad cooler that matches the theme quite well.
I recommending getting to know the NZXT S340 Elite because there's all sorts of things in the S340 Elite that you have to know when building inside it, such as the PSU bracket and the bottom drive cage. In addition to that, the NZXT Aer fans are controlled through NZXT Cam as far as I'm aware, so that's how you'll control the RGB on them once you've done the build.
Happy building, be sure to update us on when you've built your brand new PC!
