@Daniel SG1981 Bitfenix do some nice ones. The Prodigy comes to mind as it has handles.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
19 minutes ago, Daniel SG1981 said:
Mlo8 is from which brand sorry?
Silverstone.
Very compact, make sure components fit. (SFX PSU and low profile CPU cooler)
Bit pricey but probably a better fit for your son over the Bitfenix prodigy, as thats a rather large ITX case.
one of these
https://skinflint.co.uk/?cmp=954438&cmp=683671
while a bit pricey i think they are perfect little chassis if you transport them constantly
was thinking about doing a lan build in it but never came around to it.
depending on wether you need a gpu id go for the lighter and cheaper 100
"You know it'll clock down as soon as it hits 40°C, right?" - "Yeah ... but it doesnt hit 40°C ... ever  😄"
GPU: MSI GTX1080 Ti Aero @ 2 GHz (watercooled) CPU: Ryzen 5600X (watercooled) RAM: 32GB 3600Mhz Corsair LPX MB: Gigabyte B550i PSU: Corsair SF750 Case: Hyte Revolt 3
1 hour ago, Daniel SG1981 said:
I'm looking for a portable itx or matx case with a handle.
My son needs to carry it to school and home on his electric scooter.
Since he has to carry it via a scooter, I would probably stick to cases like the Silverstone ML08, The RVZ02,  Fractal Design Node 202 or another similar form factor that can fit easily into a back pack.
I'll just ask it...why not a laptop?
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
11 minutes ago, Daniel SG1981 said:
I asked him would like a laptop or a desktop he wanted a desktop cause it's easier to upgrade.
what kind of scooter are we talking about?
