Air Conditioning and Dust Prevention
28 minutes ago, Hiro Hamada said:
Typically, you'd only need a 5000 btu ( the smallest) window unit for that size of room. But given you see such high temps, I'd go for the 8,000 btu range. Over sizing ac units ins't great and reduces the effectiveness of the humidity reduction, which is the difference between being hot and being miserable and hot.
Here, btu ratings are typically used for small ac unis, and we only measure in tonnes for central units. But apparently in India you guys measure window units in tonnes, probably because it's really fucking hot. 1 Tonne is 12,000 BTU
I stuck a 10ftx10ft room with no windows not on the ground floor with floors above it into a calculator and picking some southern city, Bangalore I think, as a location, I got .75 tonne, which is about 9,000 btu I think, so I wasn't far off. Again, you dont want to oversize them, itll be more humid if you do.
I think thats about as small as you can get there, and it should be enough. If you're interested, the calc is here
https://www.bluestarindia.com/roomacs/tonnage-requirement.asp
When it asks for tube light and people, those add heat. 400 BTU person and about 340 btu per 100 watts. Remember, whatever wattage a light consumes is what it produces in heat.
I wouldn't get any bigger unless you plan to cool more than that room ,but with window units it can be hard to get the air to circulate to other rooms.
If you dont have a window, you'll have to get a portable unit (less efficient, generally suck) and pipe the heat elsewhere or get a ductless mini-split installed, which are more expensive but fairly popular there. These will require professional help to install.
