im planning on building this pc when the parts arrive what do you think?
thermaltake P3 core ATX
thermaltake 360m liquid cooler IRGB plus
thermaltake 1050w IRGB plus
32GB G-skill 3200mhz TridentZ RGB RAM sticks (4 x 8GB)
Asus Z370-F motherboard
970 Pro 1TB SSD
i7-8086K CPU
GTX 980ti G1 (will be replaced by the GTX 1180 Asus Strix in the future)
Black/Red Sleeves cables
it will look like the picture but a bit different, first i would replace the sleeves to black/red, second i would flip the power supply exposing the RGB airflow, third i would also flip the GPU into a sleeping position instead to give more room for the power supply to face me, and of course, different RAMS, different motherboards and different SSD like in the list.
the only big change i can guess is having more then just 1TB of storage but the reason why im sticking with 1TB is because it forces me to delete unwanted files and games which in turn make the PC faster so ill stick with just 1TB.
the other minor change i should of ordered the 4000mhz instead of the 3200mhz i really hope this wont impact much.
third would be is that i shouldn't of gotten the 1050w power supply, i really should of gotten the 850w the reason why i got 1050w is because i wan unaware SLI is dying.
any other changes you recommend?
https://linustechtips.com/topic/946756-building-an-open-case-pc/
it looks like you saved some money on the GPU by not getting a 1080 , but you should save by getting the 8700k instead, unless you're gonna delid and go pretty crazy with the overclock. Z370F is real nice tho, and I'm eventually gonna get it for my personal rig because of its good heatsinks.
Primary PC:
PSU tier list
How many watts do I need?
i am gonna OC the 8086K with the help of the liquid cooler, and there wasn't much different in price between the 8700k and the 8086k they were like $60 dollars different where i live, so might as well get the best out of the best
The 8086 K is basically a binned 8700 K...
but ill still get slightly higher fps, i know its not much but its something and it wasn't overly expansive
other then the CPU is there anything you think should change?
  • What are you using the PC for?
  • You don't need a PSU of that wattage. It's a waste of money.
  • Do you really need 32GB of RAM?
  • I'd save money by getting a different 2TB m.2 SSD. Do you actually need NVME?
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
Why 8086k over 8700k?
PSU is overkill wattage
A 970 pro 1tb is super expensive; if this is just a gaming pc nvme is a waste anyways, and even if you use it for something else you'd be better off with a larger 970 evo
If I were you I would get 2x16gb over 4x8gb for upgradability. 4000 MHz is also way overkill and won't give you any real advantages over a 3200 MHz kit.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
-im using it purely for 4K, HDR, 98hz(10bit) gaming (maybe a few modding for games here and there like GTA5, Sims4, skyrim)
-i know the 1050w was in overkill but i really thought SLI would be worth it i really didnt know it was dying
-i dont need 32GB RAM i need 16GB but the reason im going with 32GB ram is because i get the extra 2 ram sticks to make the build more colorful RGB, it looks alot better that way
-i do want it i hate loading times it was super long on my old hard-drive i want to completely ditch hard-drives and get the best out of the best on SSD's and 970pro is the top! and i dont want 2TB its more expansive and plus the 1TB forces me to delete things keeping my PC clean so i really think the 1TB would be good for me
- because it was a $60 different in where i live
- i know the power supply is an overkill but i really wanted to SLI my pc when the new GPU's arrive but now i changed my mind
- i wanted the 970 pro because i wanted the best of the best i know its just a few seconds different then a cheaper SSD but i really wanted this particular one
- upgradability? 32GB is alot i think the 16GB is enough, reason im getting the 4x8 is because i wanted 4 rams sticks
  • Yeah, it just doesn't make much sense, especially since SLI isn't really worth it.
  • You can get 4x4GB sticks. Or, if by the time you build, Gigabyte has their dummy sticks there's that option as well.
  • Even a regular SSD is going to be worlds faster than an HDD. NVME drives aren't that much faster at loading games than a regular SSD is. You can get a 2TB 860 EVO for the same price as the 1TB 970 PRO. Hell, you could get a 500GB NVME drive and get a 2TB Micron SSD for less than the 1TB 970 PRO.
    At the very least a 970 EVO makes more sense. There's absolutely no need to spend the extra $100 for what you're using it for.
-yup wish i did a bit of search before thinking about SLI
-G-skill does not have 4x4 jut 4x8
-ya i know but i wanted the best SSD and 1TB will force me to delete files which is good
Best SSD doesn't mean it's the best one for your build. But have fun wasting that money.
That sounds like a hassle though... a 2tb one means you don't have to bother. Or if you really insist just save some cash and get a 1tb ssd
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
I never understood the reason why people ABSOLUTELY want to prioritise looks instead of performance.
If you think that 1 TB is too small, you can always go for a higher capacity drive.
Why would you want to force yourself to delete files anyway?
i can but i dont want to, as i see it 1TB is more then enough for gaming only but sometimes i do approach 900+GB but thats only because i over download game mod files and forget to delete winrar files afterwords when im modding, and plus i like keeping the pc nice and clean but if i see that i have alot of space i just get lazy and dont do anything
33 minutes ago, saif96 said:
when you got extra cash to burn it makes you do dumb crab like that lol
By that I mean: if I have to choose between looks and performance... I go for the performance. RGB and those other fancy hypes really don't bother me.
I'm not a gamer at all. I use computers for computer calculations/simulations. In that case, you need all of the performance you can get. Simply adding RGB RAM to your system isn't going to cut it. It might look nice, but the RGB won't boost your performance! (... mind blown... ;):P)
I have a server that runs - among other things/VMs - a NAS with RAID that has more than enough storage to last me a lifetime. I literally almost never delete a file... :)
I never save a file one any of my computers. Everything is immediately saved on the server.
That's both convenient (I can access all of my files whenever I want and wherever I want) and safe (due to the RAID and the periodical offline backup).
already got a PC that has maximum performance the only thing i didnt do is watercooling, i just dont wanna risk a leak so im fine with the asus strix aircoolers
I get what you're getting into. And I think it's great. It varies from person to person, and personally, I enjoy seeing a well-built rig as much as actually using it. Some would reckon that you're looking at the screen most of the time anyway, but for me, just knowing at the back of my mind that I have a beautifully crafted rig, and seeing it beside me, makes me just want to fire it up and do some gaming.
Btw, you're rig will be awesome. Don't bother with your choice of PSU and RAM. They're good as is.
