Buying an M.2 for Taichi x470 motherboard
The difference between the two M.2 slots is, that one can use up to 4 PCI-e 3.0 lanes and that the other one can use up to 4 PCI-e 2.0 lanes - effectively only providing half the bandwith. So in short:
- M.2 PCI-e 3.0 4x - 4GB/s of Bandwith
- M.2 PCI-e 2.0 4x - 2,5GB/s of Bandwith
This is only relevant if you want to buy a M.2 NVME SSD, which can exceed the limit of 2,5GB/s.
If you buy M.2 AHCI (SATA) SSDs, you won't have to worry about it!
To your next question:
M.2 slots are nothing more than PCI-e slots, just with a different pin-layout, which are afaik always routed over the chipset and not directly to the CPU.
That means they will most likely disable a few SATA ports (usually 2) when in use.
And to your last question:
That entirely depends on your use case. I generally don't recommend to use NVMe SSDs, as they are much faster, but you most likely won't be able to make use of the speed and are more likely in need of more storage. You get a lot more storage with a AHCI (SATA) SSD, than with a NVME SSD for the same price!
