You're not gonna get anything with remotely good quality for under 25 USD.
I would save up some more cash and aim for a Corsair CX450M.
https://linustechtips.com/topic/943700-help-me-with-psu/#findComment-11497625
3 minutes ago, Guyisntcool said:
I need help with choosing a psu for an old computer
amd phenom x2 840t
2x8 ddr3
rx 550
1 hdd 7200rpm sata
psu under 25 USD
You want to run an old AMD system on a budget PSU?
Seriously though don't risk your computer by skimping on the power supply, if it fails there's a high chance of it dumping 110/220v AC straight onto the 12v DC rail which is bad, really bad.
Main Rig:-
Server:-
https://linustechtips.com/topic/943700-help-me-with-psu/#findComment-11497641
He could look for a decent used PSU, but i doubt hed find it. Itd the kind of thing people throw away once they are old.  Where you located?
https://linustechtips.com/topic/943700-help-me-with-psu/#findComment-11497659
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/943700-help-me-with-psu/#findComment-11497688
I'm getting this because it is on sale for 30 dollars
https://www.amazon.com/EVGA-Warranty-Power-Supply-100-N1-0650-L1/dp/B01LYRXRDI/ref=sr_1_3?s=pc&rps=1&ie=UTF8&qid=1530562679&sr=1-3&refinements=p_85%3A2470955011%2Cp_89%3ACorsair|EVGA|Seasonic|SilverStone+Technology|Cooler+Master|Rosewill
https://linustechtips.com/topic/943700-help-me-with-psu/#findComment-11497695
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/943700-help-me-with-psu/#findComment-11497742
https://linustechtips.com/topic/943700-help-me-with-psu/#findComment-11497750
3 hours ago, Guyisntcool said:
That's about $30 more than it should cost. Get the CX450M for $27 after rebate. At the very least, get the BT 450W.
https://linustechtips.com/topic/943700-help-me-with-psu/#findComment-11498203
4 hours ago, Guyisntcool said:
psu under 25 USD
Impossible!
Everything under 25€ is a safety risk and should not be available on the market as its highly likely that some laws would be violated with those units.
They exist, sadly, even from more reputable companys.
But seems like you have to kill your computer first to learn not to get a shitty Power Supply it seems.
Well, then good luck.
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/943700-help-me-with-psu/#findComment-11498291
