Problems and Questions with my SSDs
Solved by Radium_Angel,
12 minutes ago, Zexion said:Is there a way I can reset the SSD to the Factory settings, with NOTHING on it ?
There is...the program you are looking for is https://www.partitionguru.com/
Use with care, but it will re-combine all your partitions into one.
As for the games, I can't help. I know you can move Steam to any folder and play from there, can't speak for the other ones
