The rubber on the outside of the cable or the metal part of the cable?
My Main PC
CPUIntel Core i5 6600K CPU Cooler - Corsair H80i v2 Motherboard - ASRock Fatal1ty Z170 GAMING ITX/AC RAM - 1x HyperX FURY 8GB 2133MHz DDR4 GPU - Nvidia GTX 1060 6GB Founders Edition  Storage - 1x HyperX FURY 120GB SSD, 1x WD Blue 1TB 2.5" HDD, 1x WD Black 330GB 2.5" HDD Power Supply - EVGA Supernova 650W G3 Case - Silverstone SUGO SG13B
https://linustechtips.com/topic/939459-paint-an-aux-cable/#findComment-11458716
Yes you can paint the outside of the cable perfectly fine.
Stores sell cable wire channels or cable management systems which you can put right over cable wires to make them look neater. I think they would look better painted than just painting the cable wire itself.
https://linustechtips.com/topic/939459-paint-an-aux-cable/#findComment-11458720
Use something made to stick to rubber, like those markers people color in the text on their wheels with. I can usually find them at my local gas station
Builds:
https://linustechtips.com/topic/939459-paint-an-aux-cable/#findComment-11458722
12 minutes ago, Christophe Corazza said:
You should be extremely lucky to find an AUX cable that has exactly the same tint of colour that you need. ;-)
Who said he wanted something strange? Maybe be just wanted a red one, in that case it’s easy to find one.
https://linustechtips.com/topic/939459-paint-an-aux-cable/#findComment-11459166
https://linustechtips.com/topic/939459-paint-an-aux-cable/#findComment-11459416
