Can I connect any LED strip through a CM RGB Splitter Cable?
Solved by W-L,
On 6/15/2018 at 10:47 PM, blackd51th said:-SNIP-
The cooler master strips follow the standard 12V 4 pin RGB operation as per the header on the motherboard so you can use different brands of lights. I would recommend if you are cutting and wanting to wire up LED's yourself to grab a roll of RGB led's online and to do it yourself as it will be cheaper and more customizable.
Featured Topics
deanx ·
Posted in Troubleshooting2 -
Bkstrat ·
Posted in Troubleshooting0 -
3
remo233 ·
Posted in Power Supplies4 -
2
3
VioletGiraffe ·
PietervdWiel ·
Posted in New Builds and Planning8 -
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
