My dad's in the the military and we just moved in and I guess the movers packed my PC upside down and when I try to start it up it will stay on then turn off again than start up but the micro HDMI is not working so I can't see anything on the screen while this is happening I don't no why and I don't know how to fix it I can send photos of it if that helps but can any one help me this is my only PC.
Sincerely,
Aiden blandino
https://linustechtips.com/topic/937077-my-pc-will-not-work/
Reseat the graphics card, reseat the memory, check if all cables on the inside are firm in place etc.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/937077-my-pc-will-not-work/#findComment-11437604
9 hours ago, AskTJ said:
If it was damaged while in transit, take it to a pc shop and ask for a quote. They might cover it with insurance. If not, you will have to troubleshoot yourself.
Ok I'm pretty sure the company that moved me is gonna pay for so thanks for letting me know.
https://linustechtips.com/topic/937077-my-pc-will-not-work/#findComment-11438691
