Is there a way to deactivate caps lock? I always press it be accident when gaming which is quite annoying. I have a very normal keyboard and so do not have the advantage of programmable keys.
What is actually supposed to go here? Some people put their specs, others put random comments or remarks about themselves or others, and there are a few who put cryptic statements.
https://linustechtips.com/topic/934639-deactivate-caps-lock/
Maybe you can use something like AutoHotKey to disable it's functionabilly. I say you should just learn to not hit caps lock by accident.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/934639-deactivate-caps-lock/#findComment-11414969
https://linustechtips.com/topic/934639-deactivate-caps-lock/#findComment-11414974
14 minutes ago, AlwaysFSX said:
Pull the key cap off if it's removable.
I've done this with the Windows key before... died due to screen blanking when hitting it...
https://linustechtips.com/topic/934639-deactivate-caps-lock/#findComment-11415004
SharpKeys is easier than poking around in the registry as it does it for you.
https://download.cnet.com/SharpKeys/3000-2094_4-75803009.html
It writes to the registry so just run it once, make the changes you want then delete the program and you never need it again. I used it to rebind pgup and pgdown to be volume controls, and the Windows key to an asterisk for much the same reason you want caps lock gone.
https://linustechtips.com/topic/934639-deactivate-caps-lock/#findComment-11415015
