overclocking monitor limit?
Docretier
im trying to up the refresh rate of my monitor using AMD Radeon settings, and i have reached a point where everything goes fuzzy (like its lowering the resolution), but the screen doesn't black out like i read it should. does this mean i reached the limit of my monitor, or should i push until black to see if the picture becomes clear? i was able to get it up to 63 hz from 60, after that it just gets fuzzy
that means you reached the limit of the panel. Blackouts are caused by either the monitor rejecting the signal because it's 'above spec', or you exceed the panel's limit by a lot.
Mine goes to 147Hz before the pixels are displaced (imagine the screen cut into waffles and put all over the place)
Desktop benching:
