24" or 27" 2nd monitor?
asand1
I currently have a 27" 1080p 60Hz HP monitor. I want to pick up a 2nd 1080p 144Hz monitor for gaming and I wonder if I will be happy with 24", or if I should pick up a 27" one for the sake of symmetry? I would rather get higher quality at the expense of size. Thoughts? My goal is to be able to use discord and possibly watch streams I am participating in. I would also like to keep it under $300 as I also want to pick up an NZXT G12 and Kraken X51 at the same time.
Black Knight-
Ryzen 5 5600, GIGABYTE B550M DS3H, 16Gb Corsair Vengeance LPX 3000mhz, Asrock RX 6800 XT Phantom Gaming,
Seasonic Focus GM 750, Samsung EVO 860 EVO SSD M.2, Intel 660p Series M.2 2280 1TB PCIe NVMe, Linux Mint 20.2 Cinnamon
Daughter's Rig;
MSI B450 A Pro, Ryzen 5 3600x, 16GB Corsair Vengeance LPX 3000mhz, Silicon Power A55 512GB SSD, Gigabyte RX 5700 Gaming OC, Corsair CX430
Black Knight-
Daughter's Rig;
I would pick the 27" one for the sake of symmetry.
CPU: Ryzen 7 5800X Cooler: Corsair H100i Platinum SE Mobo: Asus B550-A GPU: EVGA RTX 2070 XC RAM: G.Skill Trident Z RGB 3200MHz 16CL 4x8GB (DDR4) SSD0: Crucial MX300 525GB SSD1: Samsung QVO 1TB PSU: NZXT C650 Case: Corsair 4000D Airflow Monitor: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
Match it to the other on for symmetry. Also 27inch give some more space to have discord open and more usable screen space.
Screen space relates to pixels, not inches though.
Unraid Server
They will both be 1080p, I'm more interseted in FPS. As I understand it a smaller screen at the same res will show objects as smaller. This would be perturbing.
Black Knight-
Daughter's Rig;
Not to mention spatially it will be annoying. If you're transitioning from the top of the smaller monitor to the bigger monitor, the mouse will appear at the top of the bigger one rather than where you'd expect. I have this problem with my 27" 4K with my 27" 1440p. PPI aware transitions just isn't a thing yet.
It really depends on how far you are sitting away from the screen.
You want to be able to see your whole screen without having to move your head if you want check the sides of it.
Unraid Server
To be honest, 2x 27 inch would look better, But since 27 inch is already so big, i do not think you can go wrong with 23 inch as second monitor either :)
Try LittleBigMouse. It adjusts mouse transitions based on PPI and your monitor positions.
I like my second 27" in portrait mode, it's really good for foobar2k or long documents and it's small enough to fit speakers nearby.
My boring Github   /人◕ ‿‿ ◕人\
