Help me with a Noctua D-15SE AMD
donalgodon
I know that the D-15SE AMD version has been shifted to allow better clearance for the first PCI slot, but what side should the shift be oriented?
I'm confused about this. I want to mount it horizontally, per the manual, but I am unsure as to which side is up/down in this orientation. If the mounting base plate is shifted, how do I know which side goes toward the PCIE slot?
Image result for Noctua D-15SE
You can tell just by looking at it.
Ah, yes. I can see the difference.
Can I add a 120 mm fan instead of the dual 140 mm setup if I don't want to choose between one fan or two 140s?
Yeah.
BTW use the quote button.
          V
