how close in comparison is the Intel Xeon E3-1240 V2 to the Ryzen 5 1600?
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
https://linustechtips.com/topic/924829-xeon-vs-ryzen-5/
Not very. It's basically the i7-3770 vs the R5 1600. The R5 is faster in both single and multithreaded workloads and can be overclocked.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/924829-xeon-vs-ryzen-5/#findComment-11322000
just google will do.
http://cpu.userbenchmark.com/Compare/Intel-Xeon-E3-1240-V2-vs-AMD-Ryzen-5-1600/m5484vs3919
If you want to compare with an overclocked 1600, use the 1600x's data.
Desktop benching:
https://linustechtips.com/topic/924829-xeon-vs-ryzen-5/#findComment-11322002
2 hours ago, NelizMastr said:
Not very. It's basically the i7-3770 vs the R5 1600. The R5 is faster in both single and multithreaded workloads.
do you think this would make a significant... say GTA V framerate diifference?
https://linustechtips.com/topic/924829-xeon-vs-ryzen-5/#findComment-11322004
well the 1240 is a quad core ivy bridge @ 3.4ghz so the 1600 would be the same-ish single core and would far surpass the 1240 in multicore.
If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
https://linustechtips.com/topic/924829-xeon-vs-ryzen-5/#findComment-11322006
2 minutes ago, Ben Quigley said:
well the 1240 is a quad core ivy bridge @ 3.4ghz so the 1600 would be the same-ish single core and would far surpass the 1600 in multicore.
u wanted to say that the 1600 would far surpass the 1240 in multicore :)
ASUS Maximus VII Hero | i7 4790K OC 4.8GHZ | 4x8GB 2400MHz MSI GTX 1070 alphacool eiswolf gpx pro
Samsung 850 EVO 520GB + Corsair 525gb + 275gb SSD  2TB Seagate Barracuda | 8TB Seagate Archive
Cooler Master HAF-X 942 | EVGA Supernova 1000W 80+ Platinum | Custom watercooling loop (gpu+cpu)
360mm+180mm rad and 10 fans | Swiftech D5 mcp655-B
https://linustechtips.com/topic/924829-xeon-vs-ryzen-5/#findComment-11322018
If you already have the Xeon, no. If you don't then I'd say yes, because the 1155 platform is getting rather old.
https://linustechtips.com/topic/924829-xeon-vs-ryzen-5/#findComment-11322023
Yeah, sorry, been staring at numbers all day. Thanks for pointing out the mistake.
https://linustechtips.com/topic/924829-xeon-vs-ryzen-5/#findComment-11322029
the situation is that i am currently looking into getting a graphics card benched on a ryzen 5 1600, and in the future i plan on getting something like thishttps://www.newegg.com/Product/Product.aspx?Item=N82E16883284588&cm_re=xeon-_-83-284-588-_-Product and im wondering if there is much of a difference.
https://linustechtips.com/topic/924829-xeon-vs-ryzen-5/#findComment-11322031
Link is broken. But I'd still advise against going with something that old. Times are changing so it's quite beneficial now to at least get a 6-core CPU.
https://linustechtips.com/topic/924829-xeon-vs-ryzen-5/#findComment-11322038
it might be a location issue but you seem to also forget i generally lack that thing called moneyimage.png.9afd435e2032d7d339c8d547e52bb563.png
https://linustechtips.com/topic/924829-xeon-vs-ryzen-5/#findComment-11322049
That's rather expensive, especially since that's a Sandy Bridge machine (notice the absence of the v2) with a slow HDD. You can find Haswell-based OEM machines for that kind of money online (HP ProDesk 400 for instance).
https://linustechtips.com/topic/924829-xeon-vs-ryzen-5/#findComment-11322078
yeah, but what if i also partially want it just to say i on a freaking xeon? also, i wasn't nessescarily getting exactly that, it was mostly an example
https://linustechtips.com/topic/924829-xeon-vs-ryzen-5/#findComment-11322131
If you want a real Xeon, get a X5670 and a 1366 board that supports it and OC the bajeezus out of it.
https://linustechtips.com/topic/924829-xeon-vs-ryzen-5/#findComment-11322154
i must return to my homework, could you pcpartpicker out a list for me?
https://linustechtips.com/topic/924829-xeon-vs-ryzen-5/#findComment-11322173
Not for old components, only for new ones. Got a budget to work with?
https://linustechtips.com/topic/924829-xeon-vs-ryzen-5/#findComment-11322183
less than 500? idk for sure but i could maybe earn that much relatively quickly
https://linustechtips.com/topic/924829-xeon-vs-ryzen-5/#findComment-11322185
For the full PC or just mobo, RAM, CPU?
https://linustechtips.com/topic/924829-xeon-vs-ryzen-5/#findComment-11322191
basically everything cept' RAM and a GPU
https://linustechtips.com/topic/924829-xeon-vs-ryzen-5/#findComment-11322196
i have some DDR3 i could use
https://linustechtips.com/topic/924829-xeon-vs-ryzen-5/#findComment-11322198
because i have a gpu coming soon hopefully and i can use the RAM in my current computer.
https://linustechtips.com/topic/924829-xeon-vs-ryzen-5/#findComment-11322208
Ugh, DDR3 doesn't work on anything Ryzen or Skylake and later. So I can't get you a list. You'll need to look for 2nd hand stuff if you want DDR3.
https://linustechtips.com/topic/924829-xeon-vs-ryzen-5/#findComment-11322221
i guess try current stuff, but i was thinking used components would be better for price/performance at this price range.
https://linustechtips.com/topic/924829-xeon-vs-ryzen-5/#findComment-11322231
It is, but pcpartpicker only does new, and I can't dig around for used parts for you as I don't know the 2nd hand scene outside of my own country lol.
https://linustechtips.com/topic/924829-xeon-vs-ryzen-5/#findComment-11322233
oh i see your problem now...
https://linustechtips.com/topic/924829-xeon-vs-ryzen-5/#findComment-11322237
