They might have discontinued it considering it's pretty old. The UK might be the only place left to get it.
What's your budget? There's likely something a lot better available.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/922007-blu-phone-help/#findComment-11294232
There's likely something better available at the same price considering the age of the BLU phone
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/922007-blu-phone-help/#findComment-11294234
2 minutes ago, Canada EH said:
No Staples online sells them
Link?
https://linustechtips.com/topic/922007-blu-phone-help/#findComment-11294252
STAY AWAY FROM BLU, BLU sells all your info, its a company that takes phones that are already made and re bands them as their own phones (they do have some of their own but most are just re branded)
also on blu since they are cheap Chinese phones EVERY SINGLE PHONE MADE BY BLU HAS THIS ISSIE, the charging port will stop working, could be in 2 days could be in one month but i dought the phone will last longer then 3 months. please just buy phone by a real reputable brand, you WILL regret buying any BLU phone,
I owned the BLU life XL, the vivo XL and the R1 I have the amazon purchase history to prove it. the longest lasting one was the R1 that lasted 5 months total. i have since bought an Iphone 8 and its been 7 months with zero issues. please please please dont buy one.
look for a used iphone 6/6s they go for like 200 used but i bet you can find a person to go $150.
and BTW BLU has better phones then the vivo 6 for less then $150
https://linustechtips.com/topic/922007-blu-phone-help/#findComment-11294313
 i curently have the blu life one x2 and its lasted me ablut 8 mounths im replacing it now becouse a friend of mine droped a friend dropped a weight on it it was a 15lbs and for blu  selling my all my info it hasnt efected me all my shoping i do on my desktop soo not sure how it would effects me
https://linustechtips.com/topic/922007-blu-phone-help/#findComment-11294332
Just get this
https://www.amazon.com/dp/B01GXAT0D8/ref=asc_df_B01GXAT0D85452132?smid=AT1DRI0SUE1WL&tag=hawk-future-20&linkCode=df0&creative=395129&creativeASIN=B01GXAT0D8&ascsubtag=trd-1359163095509293344-20
no sd card slot and iOS is pretty crappy compared to android but the phone should have good longevity. Also, se is the only good value phone in the iPhone line up.
Sudo make me a sandwich
https://linustechtips.com/topic/922007-blu-phone-help/#findComment-11294501
i would give these guys a try https://swappa.com/
CPU: Intel - Core i7-8700K @4.9 GHz 6-Core Processor CPU Cooler: be quiet! - Dark Rock Pro 3 67.8 CFM Fluid Dynamic Bearing CPU CoolerMotherboard: MSI - Z370I GAMING PRO CARBON AC Mini ITX LGA1151 Motherboard Memory: PNY - Anarchy 16GB (2 x 8GB) DDR4 @3000 MemoryStorage: 960 evo 500gbVideo Card:place holderCase: Phanteks - Enthoo EVOLV ITX TG (Black) Mini ITX Desktop Case Power Supply:SeaSonic - EVO Edition 620W 80+ Bronze Certified Fully-Modular ATX Power Supply Case Fan: be quiet! - SilentWings 3 pwm 59.5 CFM  140mm Fan Case Fan: be quiet! - SilentWings 3 PWM High-Speed 73.3 CFM  120mm Fan Case Fan: be quiet! - SilentWings 3 PWM High-Speed 73.3 CFM  120mm Fan Monitor: Dell - S2716DG 27.0" 2560x1440 144Hz Monitor Mouse: Place holder Sony H.ear on Wireless Noise Cancelling Headphone, Charcoal Black (MDR100ABN/B)  LEOBOG K26 Wired RGB Mechanical Keyboard,Gaming Keyboard,RGB Color Backlight,104 Key,Anti-Ghosting For Full Key,Blue Switches,Aluminum Chassis,Detachable wrist rest,PC,Computer, Laptop,BLACK (Black)EZDIY-FAB Sleeved Cable - Cable extension for power supply with extra-sleeved 24 PIN 8PIN 6PIN 4+4 PIN With COMBS- Black Grey
pcpartpicker: https://pcpartpicker.com/user/resdal42/saved/sCW6XL
https://linustechtips.com/topic/922007-blu-phone-help/#findComment-11294519
14 hours ago, Canada EH said:
Staples.ca
I know they sell BLU
They sell the brand, not the model.
https://linustechtips.com/topic/922007-blu-phone-help/#findComment-11296788
