Battery powered Nuc in backpack for learning to program C# anywhere
Disfikurd
 I figured this would be a good place to share my new build idea that I will be completing soon. I recently purchased a 30,000 mah battery pack, a bare bones Chinese nuc with an i7 8550u and I added 32 GB of sodimm 2400mhz ddr4 ram along with an nvme m.2 512GB ssd, a tap strap keyboard and mouse, and a royole moon wearable display. I will be carrying the computer and battery in a light backpack. I am also running Archlabs linux on the nuc. I will then put on the royole moon to use as a monitor and I will control the computer with the tap. I want to use this computer to learn programming and because of that I have installed the jet brains rider ide along with mono and dotnet core. I also have a good ebook on c# that I will be reading on the moon headset. I'll post an update with pictures once the system is ready later today.
UPDATE:
Sorry I've taken so long to follow up. I needed to get a bluetooth 5.0 dongle for the tap to work. Unfortunately my tap's mouse sensor is also malfunctioning. I had a very hard time scrolling on the computer, but once I get the replacement it should work and make the setup usable. Everything else is working and with the tap keyboard function and a normal mouse I was able to use the computer while in a backpack on battery. I have a few pictures of the final thing below. I will update this thread again once I get the new tap device and discuss the usability of this setup.
Cool idea, but you do know there exist things called laptops right?
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
Quote
The display seems to be 1080p and you will have so ensure the window is further away to prevent excessive eye movement (as if you were very close to a screen). This will noticeably decrease the resolution you can use as the window will have to be smaller and centered.
Yes, however I wanted something more immersive with the functionality of a full computer. This setup was the best solution for what I wanted to achieve.
According to the manufacturer the display appears to be an "800 inch" cinema display. Because it appears as a gigantic far display, I would think that full screen windows could be viewed comfortably without excessive eye movement. It would be like watching a movie in a cinema while sitting high up in the middle. The full display should be comfortably visible.
Ah I didn't realize what the Royole Moon was. That's different from a laptop indeed :P I don't think I would enjoy programming with that though, but that's just me.
