I have one ethernet cable to connect to 2 pcs, will this work?
VicRik
Hi guys,
My girlfriend and I want to setup her setup in my room for a week. Only one ethernet cable comes up to my room. Will this device work to split the ethernet cable into 2 usable signals? Thanks!
https://www.allekabels.nl/stekker-doos-en-krimptang/188/970/isdn-splitter-rj45.html?gclid=CjwKCAjwq_vWBRACEiwAEReprFQMc9I3HVVICoZfwDzAFUW8n3-NMocQBsONWXMag-fggXOLr7XXOBoC1jAQAvD_BwE
-VicRik
The link is dutch but the picture should make it understandable. :)
3 minutes ago, VicRik said:
Hi guys,
-VicRik
that is a phone switch lmao
use this https://smile.amazon.com/TP-Link-Ethernet-Splitter-Unmanaged-TL-SF1005D/dp/B000FNFSPY/ref=sr_1_3?s=pc&ie=UTF8&qid=1524594474&sr=1-3&keywords=ethernet+switch
or if you have gigabit, use this
just power it, pit a line of ethernet connection into any plug (use 5 its easier) then plug in 4 other connections to other devices
If my Response helped you, Please click the Check under my reply, to mark it as The Solution!
If your desktop pc has two Ethernet ports - or one Ethernet port and a wireless adapter - you could potentially connect her pc to yours and you would only need a crossover cable at most. But... switches are super cheap so unless time or money are extremely limited I'd recommend getting one of those instead. I have a D-Link 8-port TL-SG1008D switch that is about $15, but for about $10 you can get the 4/5 port version.
The switch option is much easier and means you can hook other devices up too in future.
