Why PWM fan headers?
Solved by Damascus,
10 minutes ago, Jurrunio said:so you mean it's not actually necessary, it's just a bit better?
Pretty much, its a quality of life thing.
11 minutes ago, Jurrunio said:Funny enough, the white LED on it changes brightness according to the fan speed as well (probably because both are directly related to voltage).
This is another good reason ^
