sooooo i have an i7 7700 and i use a Intel stock cooler.....Yes i know... Whatever the probelm is that turbo clocking and intel stock cooler do not match together..My cpu temp went up to 93 degrees celsius... So i went and bought the 212x cooler and my case supports 158mm coolers and the 212x is 158mm will it fit in my case????? Thanks
https://linustechtips.com/topic/918778-158mm-cooler/
If you can, return it and get a Deepcool Gammaxx 400 instead. A little cheaper, performs a little better, and stands 155mm tall. Doesn't sound like much, but those 3mm will make all the difference.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/918778-158mm-cooler/#findComment-11264121
Yes, it'll fit. The spec should already account for manufacturing tolerances. That being said, there might be a cheaper or better alternative available.
What case and ram are you using? Where are you shopping / located?
https://linustechtips.com/topic/918778-158mm-cooler/#findComment-11264265
Yes there will be quite a bit of gain the stock cooler sucks (I mean thermal performance the gains for speed will be any throttle loss + boost clocks), the temps should be under 80 for sure and likely in the mid to low 70s depending on ambient temp
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/ Tier Breakdown (My understanding)--1 Godly, 2 Great, 3 Good, 4 Average, 5 Meh, 6 Bad, 7 Awful
https://linustechtips.com/topic/918778-158mm-cooler/#findComment-11265636
the temps will go down and you'll get abit of performance back from the CPU not needing to throttle itself anymore to keep itself from overheating, but that's about it. at 93 degrees though i'd check if the push pins on the stock cooler were unseated, or if the fan is moving much slower and if the thermal paste is dried up.
https://linustechtips.com/topic/918778-158mm-cooler/#findComment-11265638
On 4/21/2018 at 7:42 AM, AresKrieger said:
Yes there will be quite a bit of gain the stock cooler sucks, the temps should be under 80 for sure and likely in the mid to low 70s depending on ambient temp
Thanks so much for the help!
I checked the stock cooler and it is secure to the mobo. The contact metal is aluminium so i think thats why temps went up so high. Copper is much better... and I use my PC for 6 hrs straight.
Thanks for the help!
https://linustechtips.com/topic/918778-158mm-cooler/#findComment-11265639
On 4/21/2018 at 7:54 AM, Froody129 said:
Also try undervolting. That should give a very big drop in temps. It's pretty easy using Intel XTU
But the frequency will drop if I undervolt i dont want that.
my i7 7700 has a temp of 73-78 degrees celsius is that fine? Thanks.
https://linustechtips.com/topic/918778-158mm-cooler/#findComment-11265725
on load or idle?
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/918778-158mm-cooler/#findComment-11265827
idle: that's f****** high.
Full load under stress test: it's fine.
Desktop benching:
https://linustechtips.com/topic/918778-158mm-cooler/#findComment-11265840
4 minutes ago, MaccaB said:
while playing fortnite or r6 so i think tahts fine right?
then it's a bit high, but not to a worrying level yet.
Desktop benching:
https://linustechtips.com/topic/918778-158mm-cooler/#findComment-11265858
Are you using the stock Intel cooler?
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/918778-158mm-cooler/#findComment-11265882
1 minute ago, MaccaB said:
Yes i am.
That'd be why. If you want decent temperatures you have to invest in a better cooler.
https://linustechtips.com/topic/918778-158mm-cooler/#findComment-11265890
Just now, MaccaB said:
I bought the 212x and some arctic paste. Im new to PC building are those good parts?
212x is a cooler? If you have a 212x cooler then you're not using the stock cooler. Thermal paste won't make a huge amount of differnce
important figure in mensa
https://linustechtips.com/topic/918778-158mm-cooler/#findComment-11265895
 It's ok but the CryOrig H7 is better. Generally they come with thermal paste, so you don't really need to buy any.
https://linustechtips.com/topic/918778-158mm-cooler/#findComment-11265900
I ordered it online im still using the stock cooler for now.
The problem is my case it only supports 158mm cpu coolers. and the 212x is 158mm
https://linustechtips.com/topic/918778-158mm-cooler/#findComment-11265901
It only supports up to 158mm coolers. You can use smaller ones. The H7 is 148mm.
Since you already bought the other one though it should be fine. You can't overclock so you're not going to be making excessive heat at the CPU anyway.
https://linustechtips.com/topic/918778-158mm-cooler/#findComment-11265983
