4k vs UltraWide vs... for 2nd display
Mikealongo
Hi to everyone, i posted a few days ago a topic about getting a second monitor, i guess that the lack of coments was because of the lack of information, so im going to put all the information in hear (such as main purposse, budget, alternatives and so on):
+The main purposse will be using it as a second monitor for my pc (that means, web browsing while gaming, media content while gaming, chatting while gaming, productivity while working...). I would love to be able to play with my PS4 or Switch in it aswell, in Full screen mode, Picture in Picture or Picture by Picture (i remember watching some ultrawides monitors wich are capable to have two inputs one in each half correct me if im wrong (the "PIP" or "PBP" mode is not that usefull in that case because i will have my main monitor anyways so...), so i guess the input number is important in that case.
+Now im ussing a asus swift pg278q wich is a 1440p, 27 inches, G-Sync monitor (vital information because of the size, i guess i should go something like 27 inches)
The budget is something between 0 - 350€ more or less.
+The first alternatives at this moment are (keep in mind that you can recomend something better and more expensive if it is worth it):
-HP 27w: 1080p, 27 inches, IPS only one HDMI at 160€; not a big fan of it because of the low pixel density and the input lack.
-ASUS PB277Q; 1440p, 27 inches, Tn, 1 HDMI, 1 DP at 280€; i guess this is thea easy pick because its the same resolution and size as the current one, but at that price i wonder if going 4k or ultra wide is a better move.
-Samsung U28E590D: 4K, 28 inches, TN, 2 HDMI, 1 DP at 290€; I dont know if it is worth it for a second monitor to go with this one or if it is overkill, but really temptating... (LTT review) Edit (it have PIP and PBP, but its too old i guess)
-LG 29UB67-B or 29UM69G-B: 1080p ultrawide, "29 inches", the first one have 2 HDMI and 1 DP, the second one 1 HDMI 1 DP at 280€ both of them.
I dont know wich way to go, 1080p, 1440p, 4K, 1080p ultrawide or even 1440p ultrawide (i didnt consider that option yet), I want to know your thoughts about this and wich monitor would you recomend mi (not necesary one of the ones i mentioned)
Thanks to everyone =)
Go a ultrawide if you can afford one or even one of the cheap ones. Way more real estate for multitasking. 1440p UW can easily do 3 web browsers or such side by side
So can 2560*1080. Like my monitor.
↓ ↓ ↓ ↓ ↓ ↓ ↓ ↓ ↓ ↓ ↓ ↓ ↓ ↓ ↓ Specs ↓ ↓ ↓ ↓ ↓ ↓ ↓ ↓ ↓ ↓ ↓ ↓ ↓ ↓ ↓
PC Specs:
CPU: Intel Core i7-12700K 3.6 GHz 12-Core
CPU Cooler: Corsair iCUE H150i ELITE CAPELLIX 75 CFM Liquid CPU Cooler
Motherboard: Asus ROG STRIX Z690-E GAMING WIFI ATX LGA1700
RAM: Kingston FURY Beast 32 GB (2 x 16 GB) DDR5-5200 CL40
Storage: Boot Drive: Samsung 960 Evo 250GB M.2 NVMe SSD
               Other Storage: Mass Storage: Western Digital Caviar Blue 1TB 7200 RPM, Western Digital Caviar Blue 2TB 5400 RPM, Scratch Disk: Intel X25-E SSDSA2SH032G1 32GB SATA II SSD, Backup Drive: Seagate ST3160318AS 160GB HDD
GPU: Asus GeForce RTX 3080 Ti 12 GB ROG STRIX GAMING OC
Case: Corsair 5000D AIRFLOW ATX Mid Tower
PSU: Silverstone Strider Platinum S 1000 W 80+ Platinum Certified Fully Modular ATX
OS: Windows 11 Pro 64-Bit
Monitors: Primary: Samsung S34E790C 34" 3440*1440 60 Hz UWQHD; Secondary: LG 34UM58-P 34" 2560*1080 75 Hz UWFHD; Tertiary: BenQ GL2460 24" 1920*1080 60 Hz FHD
Keyboard: Corsair K70 Mk. 2 RGB Gaming Keyboard - Black
Mouse: Corsair M65 Pro RGB FPS Gaming Mouse - Black, Logitech MX Master 3
Headphones: Corsair VOID PRO Surround Cherry 7.1ch
Speakers: Logitech Z213 7W 2.1ch
Laptop:
Asus Zenbook Pro 15 (UX535Li-E2018T) with Intel Core i7-10750-H 12MB @ 2.60GHz (Turbo @ 5.0 GHz), 16GB (2 x 8GB) DDR4 2933 MHz SODIMM and Intel(R) UHD Graphics; NVidia Geforce GTX 1650-Ti with Max-Q Design, using WDC NVMe PC SN730 SDBPNTY-1T00-1102, on a 96-Wh battery
NAS Specs:
Make & Model: QNAP TS-1277
CPU: AMD Ryzen 5 1600 @Stock
Hard Drives: x8 WD Red 2TB
SSDs (2.5"): x1 Samsung 850 Evo 250GB V-NAND (cache drive)
M.2 SSDs: None
RAID Configuration: RAID 6 (excluding SSD)
Total Storage: 12TB
Expansion Cards: None
Hmm honestly, ultra wide is temting too, but remember that its going to be a Secondary monitor, in the main one I have G-sync, so my main concern is if the uw is going to be worth it and wich UW is the best to pick considerig my budget
Thanks for the replays =)
Well do it if you have enough room on your Desk
PC Specs:
Laptop:
NAS Specs:
M.2 SSDs: None
Total Storage: 12TB
 ultrawides are better imo for productivity and browsing although I prefer my 4k monitor for gaming. For browsing etc a 2560x1080p will probably be enough, but you might want to go for one with a decent VA or IPS panel with atleast ok color reproduction. shouldnt be hard to find a 1080p UW for less than 300e
I dont recommend 4K just because windows scaling still isnt great
Winning an argument with a woman step by step
step one - talk to her
step two - fight with her for 2 hours even if you are really right
step three - admit that she is right for the sake of your safety
step four - realize that you have accomplished nothing and she still thinks you were wrong and now she thinks you are even more stupid
GTX1080ti, I5-4690k, ASUS Z97 PRO-GAMER, 8GB DDR3 1600mhz, Hyper 212 EVO, Tt view 31 RGB.
hmmm not in my desk, but if i buy the UW one i will put it in the wall above the 1440p one, i just realized how wide the UltraWide is (72 Cm)
keep in mind that it will be a 2 monitor setup so maybe going without the ultra wide is a better move if i can get better quality or better price/quality ratio.
  • 3 months later...
I wouldn't recommend an ultrawide as a secondary screen. You will have to move your head way to much to see anything. I will be way out off your vision if you are watching a movie for example. However an ultrawide as primary with a smaller screen as secondary could be handy.
Secondary screen normal 27 inch ips and buy a stand to pick both :P
Case: Corsair 760T  |  Psu: Evga  650w p2 | Cpu-Cooler : Noctua Nh-d15 | Cpu : 8600k  | Gpu: Gygabyte 1070 g1 | Ram: 2x8gb Gskill Trident-Z 3000mhz |  Mobo : Aorus GA-Z370 Gaming K3 | Storage : Ocz 120gb sata ssd , sandisk 480gb ssd , wd 1gb hdd | Keyboard : Corsair k95 rgb plat. | Mouse : Razer deathadder elite | Monitor: Dell s2417DG (1440p 165hz gsync) & a crappy hp 24' ips 1080p | Audio: Schiit stack + Akg k712pro + Blue yeti.
