Case Dilemma: 900D or 750D for WC Build
Solved by airdeano,
Ended up pulling the trigger on the 750D. I have the parts listed below for my WC setup, went with 7/16 tubing and 1/2 barbs I have read you can do this and not have to use anything to hold the tubbing down. Thoughts?
Alphacool NexXxoS UT60 Full Copper 240mm
Alphacool NexXxoS UT60 Full Copper 360mm
EK-Supremacy Clean CSQ - Nickel + Plexi
I believe I will have to use some sort of SLI fitting as well, still looking at those.
looks good, fans?
only issue i can bring up would be the stubby fittings might be too short in this
idea of having a tight radius will not have a good enough support to hold a seal.
i'd toggle the idea with the standard barbs with some grab, because of not using
clamps. i love the 7/16" on 1/2" barb, but in a tight radius loop you might need
length on that fitting. just a thought. got the order put in yet?
