It's a shitty APU trying to run a heavily modded version of Minecraft. There's nothing you can do.
https://linustechtips.com/topic/91294-mc-fps-issues/#findComment-1231856
Install Optifine and hope for the best.
Corsair 900D | MSI MPower Max Z87 AC | i7-4790K @ 4.7Ghz | 1080 Ti SLI | 16GB Corsair Vengeance Pro 2400
XSPC Raystorm | EK-FC Nickel GPU block/backplate | 2x Alphacool UT60 480mm & XT45 240mm | 11x Linus Edition NF-F12
Schiit Modi/Magni 2 Uber | 5" KRK Rokit G3 | KRK 10S2 | Acer Predator X34 | Dell S2716DG
https://linustechtips.com/topic/91294-mc-fps-issues/#findComment-1231869
^^ Couldn't have said it better myself
@OP The only two things you can do is overclock if your able to or upgrade.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/91294-mc-fps-issues/#findComment-1231939
Samly, 1. Not an option. 2. Not an option. I wish i could build my own system
Well then your option is to drop some mods until you can run it properly or have it run like crap.
https://linustechtips.com/topic/91294-mc-fps-issues/#findComment-1231942
Playinon a server, take some mods that i can wit the SMP world i have and it doesent help, Might go and install optifine and turn EVERYTHING that i can down. I can use it on a server with out the server having it on it right?
Buy all the planes! Im also bad at quoting!
https://linustechtips.com/topic/91294-mc-fps-issues/#findComment-1231949
Your last sentence makes no sense.
https://linustechtips.com/topic/91294-mc-fps-issues/#findComment-1231953
How? I thought it was supposed to help with your performance. I'll just not question it. Even though i just did. :P
If you can't run MC without Optifine, there's no reason to not give it a shot... The likelihood of it dropping your FPS further is slim to none. It has only improved framerates on about 15 computers (that I have personal experience with). I'm not too sure what tea1337 is talking about.
https://linustechtips.com/topic/91294-mc-fps-issues/#findComment-1232065
You can do that, but Optifine might also drag your fps down even lower.
Why's that....?
https://linustechtips.com/topic/91294-mc-fps-issues/#findComment-1232795
Why's that....?
When I had my old system about 8 months ago to play just minecraft on I got about 19 fps, my friend told me to install optifine and showed me how and stuff, the correct one too. He said it would help out my fps but when I played with it on at the same settings I got 4 fps lower. I could have just been my system, it wont happen to all.
https://linustechtips.com/topic/91294-mc-fps-issues/#findComment-1233399
I saw the title and i was expecting a new menu item at mcdonalds. The McFpsIssues xD
https://linustechtips.com/topic/91294-mc-fps-issues/#findComment-1233514
Well, it helps in most cases. Maybe you were using the wrong settings.
https://linustechtips.com/topic/91294-mc-fps-issues/#findComment-1235330
