Triple monitor low hz (30)
So i've got a triple monitor setup
x2 LG 27UD68-P & PG27VQ running on a Asus 1080TI Poseidon.
The problem is that the PG27VQ needs a Displayport cable to run higher than 60Hz 1440p.
But the LG monitors are 4K and also need a display port cable to run a smooth 60hz on 4k.
So 1 of the LG screen is running a HDMI cable which locks it to 30hz, is it possible to add a second HDMI cable to run 60hz or some other solution?
Quote or mention me if not feel ignored
Does the PG27VQ have DVI-D by any chance? you could use dual link dvi-d to achieve 1440p60hz so you could shift the DP to the other monitor.
Personal Desktop":
Luna, the temporary Desktop:
Try to find a DVI-D dual link to DP adapter or cable.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
Displayport hub
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
Dual link will not go to 4k 60 Hz
2 minutes ago, JDE said:
Displayport hub
This wont help me either since DP 1.2 barely does 60hz on 4k
Well, your monitors are the issue here. The card has HDMI 2.0, which does 4K60 no problem, it's part of the spec. So you have 4 4K capable ports. So if your LG monitors don't support HDMI 2.0 then that's shoddy work on LG's part.
