well, it;s not the first refresh they do. basically i suspect the same design but with some slightly better hardware, just like every time.
https://linustechtips.com/topic/912425-razer-blade-2018/#findComment-11202206
4 minutes ago, Surge_Shock said:
What are your guys' thoughts on razer making a 2018 refresh of the razer blade? What do you think it would have?
I think they're going to refresh soon still using 10 series GPU's. Maybe going from a 1060 to a 1070 MaxQ if thermals allow.
They'll probably upgrade the track pad and maybe add a magnetic charging solution or charging my USB Type C.
Obviously they'll move up to an 8 Series CPU too.
Form factor will remain unchanged though.
See my Build here!
Intel 6700k -  Strix GTX 1080Ti - Corsair AX760 - Corsair Dominator 16GB 3000MHz - ASUS Maximus VIII Hero
Seagate Barracuda 1TB -  Samsung 120GB 840 - Samsung 840 EVO 250GB - Corsair H100i - Corsair Air 540 White -
Corsair AF120 - 2x Noctua NF-F12 - 3 x Noctua NF-S12
 Dell S2417DG - Dell UH2515H
https://linustechtips.com/topic/912425-razer-blade-2018/#findComment-11202211
I'd love to see them change the exhaust port location though. I can't stand that so many laptop manufacturers are now putting exhausts in the hinge so it can block the heat trying to escape, maybe one day we'll get a side exhaust, or a hinge design that doesn't block the heat escaping.
Desktop: i9 11900k, 32GB DDR4, 4060 Ti 8GB 🙂
https://linustechtips.com/topic/912425-razer-blade-2018/#findComment-11202243
-4k -touchscreen +big battery +silent cooler(more heatpipes).
A laptop's first purpose is being portable, it's stupid giving up battery life for a 4k screen when Windows doesn't not support 4k resolution on all apps and scaling does not work that well, also having a bigger price and using system resources for a feature that you never use is also stupid(talking about touchscreen now).
https://linustechtips.com/topic/912425-razer-blade-2018/#findComment-11202347
Improve build quality, cooling and QC first. Also customer support. If they don't improve on these then I won't even bother to get one.
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/912425-razer-blade-2018/#findComment-11204785
Probably the same design as before but with new CPUs and GPUs.
I would prefer that they focus on QC and cooling. I never recommend Razer Blades for these factors alone
The Workhorse (AMD-powered custom desktop)
CPU: AMD Ryzen 7 3700X | GPU: MSI X Trio GeForce RTX 2070S | RAM: XPG Spectrix D60G 32GB DDR4-3200 | Storage: 512GB XPG SX8200P + 2TB 7200RPM Seagate Barracuda Compute | OS: Microsoft Windows 10 Pro
The Portable Workstation (Apple MacBook Pro 16" 2021)
SoC: Apple M1 Max (8+2 core CPU w/ 32-core GPU) | RAM: 32GB unified LPDDR5 | Storage: 1TB PCIe Gen4 SSD | OS: macOS Monterey
The Communicator (Apple iPhone 13 Pro)
SoC: Apple A15 Bionic | RAM: 6GB LPDDR4X | Storage: 128GB internal w/ NVMe controller | Display: 6.1" 2532x1170 "Super Retina XDR" OLED with VRR at up to 120Hz | OS: iOS 15.1
https://linustechtips.com/topic/912425-razer-blade-2018/#findComment-11204887
Yep. My GL502VM has the same flaw
Don’t understated why the designers thought it was a good idea. Granted, the GL503 got around it (still runs warm) but damn
https://linustechtips.com/topic/912425-razer-blade-2018/#findComment-11208129
1- 15.6 1440p 120hz screen with brightness up to 520 nit
in the same chassis size or a slightly bigger one
2- Extra M.2 slot
3- GTX 1070 MaxQ
4- 94 Whr battery
5- illuminating function Keys
6- 2 year standard warranty
7- Better cooling ( less fan noise  )
8- SD card reader
GOOD TO HAVE:
1- space grey or silver version while keeping the razer chroma keyboard
2- A Ram slot
3- Better Webcam & mic
4- Magsafe
https://linustechtips.com/topic/912425-razer-blade-2018/#findComment-11223253
2- Extra M.2 slot
3- GTX 1070 MaxQ
4- 94 Whr battery
8- SD card reader
GOOD TO HAVE:
2- A Ram slot
4- Magsafe
Thats Pretty much everything I want!!!
Only things i wouldnt need is:
- Better Webcam/Mic [I have Headphones]
- Magsafe [What even is this???]
- Ram Slot
- SD Card Reader
But good idea with space grey/silver Colors! Id love to see that!
But i would probably go for the black version because if I got a Razer Blade, id probably go and get a Skin for it from Dbrand, since they have some dope skins for it!
https://linustechtips.com/topic/912425-razer-blade-2018/#findComment-11238556
Doubt it, they can barely handle a 1060.
https://linustechtips.com/topic/912425-razer-blade-2018/#findComment-11238575
2- Extra M.2 slot
3- GTX 1070 MaxQ
4- 94 Whr battery
8- SD card reader
GOOD TO HAVE:
2- A Ram slot
4- Magsafe
good to gave 1 is a must
also o want a 14 inch in 13.3 size with a max q 1060 abd 15.6  with a mac 1070
https://linustechtips.com/topic/912425-razer-blade-2018/#findComment-11258533
Guys, there's literally no reason to discuss Razer laptops unless they fix their terrible build quality and QC. There are tons of YouTube videos by well-known laptop repair experts about how bad is the quality of Razer laptops.
Desktop specs:
https://linustechtips.com/topic/912425-razer-blade-2018/#findComment-11258659
The Zephyrus has a unique cooling design.
https://linustechtips.com/topic/912425-razer-blade-2018/#findComment-11258685
This is one thing any tech enthusiast should know. You may get "portability" and "performance" but quality is just awful.
https://linustechtips.com/topic/912425-razer-blade-2018/#findComment-11258687
Even non gaming laptops like my HP Envyx360 have their port there. Do anything moderate to heavy and the fans spin up quite loud and on heavy loads the metal becomes so hot that its like a frying pan. The exhaust gets covered in tent and tablet modes
https://linustechtips.com/topic/912425-razer-blade-2018/#findComment-11258695
Kill it with fire. Oh wait. They already do. LOL.
Laptop Main
(Retired) Zbook 15: i7-6820HQ, M2000M, 32gb, 512gb SSD + 2tb HDD, 4k Dreamcolor
(Retired) Alienware 15 R3: i7-6820HK, GTX1070, 16gb, 512 SSD + 1tb HDD, 1080p
(Retired) T560: i7-6600U, HD520, 16gb, 512gb SSD, 1620p
(Retired) P650RS: i7-6820HK, 1070, 16gb, 512gb + 1tb HDD, 4k Samsung PLS
(Retired) MBP 2012 Retina: i7-3820QM, GT650M, 16gb, 512gb SSD, 1800p
https://linustechtips.com/topic/912425-razer-blade-2018/#findComment-11261612
2- Extra M.2 slot
3- GTX 1070 MaxQ
4- 94 Whr battery
8- SD card reader
1. Show me the panel model in Panellook. Doesn't even exist right
3. Can't even handle a 1060, leave alone 1070MQ
4. Show me the space for bigger battery
6. Won't even last for a year, leave alone the 2 year warranty. Oh yeah good luck dealing with their famous terrible customer support
7. Impossible in such form factor, even worse with Blade terrible cooling design
Desktop specs:
https://linustechtips.com/topic/912425-razer-blade-2018/#findComment-11261704
On 4/4/2018 at 10:35 AM, Surge_Shock said:
What i'd like to see is
- 1440p Screen
- 120hz Screen
- Type-C Charging [the laptop charges with type c]
- Less Bessel on the screen
- Matte screen [Not glossy]
- RGB Razer Logo!
I agree.  I've been holding off on buying one because I would love for it have less bezel and USB C charger.
https://linustechtips.com/topic/912425-razer-blade-2018/#findComment-11270210
I rather have an Alienware. But if I really have to choose, I don't think I would even get an Alienware either. (says the guy who got an faux-Alienware)
Gaming Laptop Specs (Dell 7577):
Intel Core i7-7700HQ @ 2.8GHz (4C8T)
Nvidia GTX 1050 Ti 4GB (stock)
8GB DDR4 2400MHz
128GB SSD + 1TB HDD
Windows 10 Home
https://www.carthrottle.com/user/ferrari_v12_kicked_in_yo/
https://linustechtips.com/topic/912425-razer-blade-2018/#findComment-11271862
It would be nice if they get their cooling under control. I would love to see one made with options like the aero 15x. I just got it and I like it but a Razer version with a similar setup would be better imho. The gigabyte software kinda stinks.
Ideally if Razer fixed their cooling problem, has a 90whr or higher battery, and high refresh rate without gsync I would get rid of the aero and buy the Razer in a heartbeat.
https://linustechtips.com/topic/912425-razer-blade-2018/#findComment-11287863
