So far I got these things for my rig https://pcpartpicker.com/list/sWGdXP (I will wait until new GPU's are out for 1440p 144hz gaming) Any changes I should consider before buying ram/modo/cooler/cpu?
CPU: Intel - Core i7-8700K @4.9 GHz 6-Core Processor CPU Cooler: be quiet! - Dark Rock Pro 3 67.8 CFM Fluid Dynamic Bearing CPU CoolerMotherboard: MSI - Z370I GAMING PRO CARBON AC Mini ITX LGA1151 Motherboard Memory: PNY - Anarchy 16GB (2 x 8GB) DDR4 @3000 MemoryStorage: 960 evo 500gbVideo Card:place holderCase: Phanteks - Enthoo EVOLV ITX TG (Black) Mini ITX Desktop Case Power Supply:SeaSonic - EVO Edition 620W 80+ Bronze Certified Fully-Modular ATX Power Supply Case Fan: be quiet! - SilentWings 3 pwm 59.5 CFM  140mm Fan Case Fan: be quiet! - SilentWings 3 PWM High-Speed 73.3 CFM  120mm Fan Case Fan: be quiet! - SilentWings 3 PWM High-Speed 73.3 CFM  120mm Fan Monitor: Dell - S2716DG 27.0" 2560x1440 144Hz Monitor Mouse: Place holder Sony H.ear on Wireless Noise Cancelling Headphone, Charcoal Black (MDR100ABN/B)  LEOBOG K26 Wired RGB Mechanical Keyboard,Gaming Keyboard,RGB Color Backlight,104 Key,Anti-Ghosting For Full Key,Blue Switches,Aluminum Chassis,Detachable wrist rest,PC,Computer, Laptop,BLACK (Black)EZDIY-FAB Sleeved Cable - Cable extension for power supply with extra-sleeved 24 PIN 8PIN 6PIN 4+4 PIN With COMBS- Black Grey
pcpartpicker: https://pcpartpicker.com/user/resdal42/saved/sCW6XL
https://linustechtips.com/topic/911159-planning-help/
I'd swap that Thermaltake PSU for a Seasonic one, and go with an NZXT case. That is my personal opinion, and you may follow it or not. Now looking at it, why go Mini ITX? Mind reasoning? +if you go with a small case, choose an NZXT or Corsair liquid cooler for that CPU. Especially in a small form factor case where a tower cooler might not be the best choice.
General Electric GE90-115B: i7 2600k @4.0Ghz + ID-Cooling Frostflow+ 120 / MSI Z77A-GD65 / 4x4G DDR3 1333Mhz / Nvidia GeForce GTX 760 Ti + NZXT Kraken G12 + Corsair H75 / Seasonic M12II-620 EVO 620W / Kingston SV300 120G (boot) + Western Digital WDC10EFRX 1TB / Fractal Design Focus G / 3x Corsair AF140 + 1x Bitfenix Spectre Pro Black 140 mm
https://linustechtips.com/topic/911159-planning-help/#findComment-11190502
I want to get parts that will last me for other builds (that is why I got that cooler, do not want my water cooler to snap off during a flight), I travel a lot from US, South america, Russia/Europe, and even if that case is big for an ITX I like how it looks. I might go for a seasonic one but I will ultimately go with a cheap (in discount) good powersupply, that thermaltake one is mainly for the pice (do not care about rgb) if a good one with a good price appears I will go for it.
https://linustechtips.com/topic/911159-planning-help/#findComment-11190526
I know that the corsair rmx line of power supplies have a 10 year warranty so it should last you for other builds. Just be cearfull so that you know it will fit your case. I have a matx version of that phanteks case and my rm750x only fit if i remove the drive cage.
https://linustechtips.com/topic/911159-planning-help/#findComment-11190540
I see. Even though, a hefty tower cooler has a bigger chance of snapping off than a liquid one. Just think about the weight. As far as the form factor, i see. No problems then. I might as well go out and say to not cheap out on the PSU because if it goes down, it can and will take down things with it, like the moterboard, RAM, HDD/SSD, etc. I bought a Seasonic M12II-620W PSU for an i7 2600k, 16gigs of ram, a GTX 760TI, an SSD, an HDD, 2 AIO liquid coolers, and their fans, and crammed everything inside a Focus G form Fractal Design. The PSU costed more than the case.But i don't want something to die because i cheaped out on the most important component.
https://linustechtips.com/topic/911159-planning-help/#findComment-11190546
I understand that, but I am not buying an obscure PSU either. That Thermaltake is a mediocre one, yes. Would I look into nicer ones? yes if the price is right at the time of purchase. The air cooler can always be removed, so no issues there
https://linustechtips.com/topic/911159-planning-help/#findComment-11190554
Seasonic Focus Gold and Focus Plus Gold have excellent pricing at the moment  When selecting a psu remember that it directly affects component lifetimes, system stability, and overclocking potential.
I am quite confused by the thought that a relatively light, roughly 40mm tall aio pump housing has more of a chance of ripping off its mounts than a more than 2.5 lb 163mm tall air tower. The physics alone dictate just the opposite. It will be necessary to brace or remove the Dark Rock Pro 3 before any extensive travel.
The memory modules look to be too tall to fit under the Dark Rock Pro 3.
If you are not buying everything at roughly the same time I would suggest waiting until that is possible. While we may think we have a good handle on new introductions we are as often wrong as right.
https://linustechtips.com/topic/911159-planning-help/#findComment-11190722
Oh, not because of that is why I do not want and IO. I do not want to deal with evaporating coolant over the years, or sudden leaking when I am not in the sates and warranty is limited. I much rather go with as little moving parts as possible. I will have to mod the memory, yes, just bare PCB. The only component I am waiting to come out is the GPU. I have the time to wait. but ryzen 2 doesn't seem that will fare as well in gaming as far as leaked performance data show. But by the time the gpu's are out I will have the proper reviews. Looking into PSU's now.
https://linustechtips.com/topic/911159-planning-help/#findComment-11190738
spend abit more on a better mobo and faster ram, swap out the smart pro rgb for a better seasonic focus.
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  ($347.79 @ OutletPC)
CPU Cooler: Reeven - Justice 82.1 CFM Sleeve Bearing CPU Cooler  ($42.99 @ Newegg Marketplace) on par with 240mm AIOs.
Motherboard: MSI - Z370I GAMING PRO CARBON AC Mini ITX LGA1151 Motherboard  ($149.99 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($164.89 @ OutletPC)
Storage: Crucial - MX500 1TB 2.5" Solid State Drive  (Purchased For $204.00)
Video Card: Zotac - GeForce GTX 1080 Ti 11GB AMP Extreme Core Video Card  ($914.98 @ Newegg)
Case: Phanteks - Enthoo EVOLV ITX TG (Black) Mini ITX Desktop Case  (Purchased For $67.99)
Power Supply: SeaSonic - FOCUS Gold 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($59.99 @ Newegg)
Case Fan: be quiet! - SilentWings 3 PWM High-Speed 73.3 CFM  120mm Fan  (Purchased For $13.75)
Monitor: Dell - S2716DG 27.0" 2560x1440 144Hz Monitor  (Purchased For $240.00)
Mouse: Logitech - G602 Wireless Optical Mouse  (Purchased For $23.75)
Other: Phanteks PH-CB-CMBO_BW 19.68" 24 Pin/ 8pin (4+4) M/B, 8pin (6+2) PCI-E  ($28.72 @ Amazon)
Other: Sony H.ear on Wireless Noise Cancelling Headphone, Charcoal Black (MDR100ABN/B)  (Purchased For $130.00)
Other: LEOBOG K26 Wired RGB Mechanical Keyboard,Gaming Keyboard,RGB Color Backlight,104 Key,Anti-Ghosting For Full Key,Blue Switches,Aluminum Chassis,Detachable wrist rest,PC,Computer, Laptop,BLACK (Black)  (Purchased For $19.57)
Total: $2422.16
Generated by PCPartPicker 2018-03-30 22:17 EDT-0400
https://linustechtips.com/topic/911159-planning-help/#findComment-11191737
took your advice and bought the  m12ll it should soon arrive :)
https://linustechtips.com/topic/911159-planning-help/#findComment-11193693
cancel the order for the M12ii and get a corsair CX or masterwatt instead, the M12 is old as dirt and missing several protections, it's not a good unit.
https://linustechtips.com/topic/911159-planning-help/#findComment-11194367
even if I bought the evo version?
https://linustechtips.com/topic/911159-planning-help/#findComment-11194575
yes.
https://linustechtips.com/topic/911159-planning-help/#findComment-11194583
What protections? Are you kidding me? Even if it is "old and dirt", the fact that it is still around, it means that customers are happy about it, with no further design changes needed. I've had an M12ii for over 6 months in my current build and it runs like a dream. Before i had some corsair, thermaltake, cooler master and evga PSUs and all of them went wrong in under 5 months of my workflow. The seasonic was the only one which passed the 6 month mark and isn't broken down because of shit caps, blown trannies, charred circuits or literally on fire.
https://linustechtips.com/topic/911159-planning-help/#findComment-11199873
3 hours ago, Al3x_B0ss said:
What protections?
no OCP and UVP on the 12v rail.
the fact that it's still around means that seasonic is so damn lazy that they can't be assed to make an updated unit for their low-end power supplies, nothing more.
so? have you tested for ripple and voltage regulation with specialized equipment? or are you just the typical amazon review spammer who goes "works for 10 seconds must be the best" or "CAME DOA ITEM MUST BE SHIT" the second one unit comes defective?
which means anything, how? all 4 of those companies have sold crap before, and even if you got a decent model from them doesn't mean they're 100% immune to failure. just because your one precious M12ii didn't immediately blow up doesn't excuse it from being ancient.
https://linustechtips.com/topic/911159-planning-help/#findComment-11200521
They were supposed to have released a line of PSUs to replace the old S12ii and M12ii last year. Honestly not sure what happened to them... I think it was supposed to be the Core lineup?
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/911159-planning-help/#findComment-11200547
Thanks
https://linustechtips.com/main/topic/858096-why-you-shouldnt-buy-a-s12iim12ii-in-2017-or-later-years/
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/911159-planning-help/#findComment-11201091
MIne does have OCP and UVP on the 12v rail. Tested by identifying the individual 12V conductors at the PSU modular interface and using a digital load to overload the 12V rail to 240VA as per IEC 60950-1. And the PSU immediately shut down, not frying itself.
Can't say no about that.
I did test these PSU's with "specialised equipment" and as far as ripple frequency goes, the newer Corsair CX or the Seasonic FOCUS have better ripple, but not by a whole lot. Voltage regulation, yeah. Of course. With my favourite D&V Electronics VRT-10 from the laboratories at Tokyo University, from which I am an alumni.
Of course, all companies have sold crap before, but I found the jackpot in this unit from Seasonic which is better built than others. Yeah, OK, it is ancient, but so is earth and nobody complains about it kappa. And to make one thing clear, I am no fanboy of either Seasonic, Corsair, EVGA, etc. I just take what is best withing a price range. And one thing I despise about it is the cables. Man they're bad. But easy to mod. Very easy infact. Especially the 24-pin T H I C C cable. No flat here. srsly Seasonic? smh.
https://linustechtips.com/topic/911159-planning-help/#findComment-11201113
Well, it isn't rated for such according to the SeaSonic website. Your unit must be a special one.
The problem is the price. I'd recommend it if it was $15-20 and you needed a quick fix. But it's usually priced above the DC-DC modern CX450/CX450M. Might as well. That's the problem with the M12II. Everyone recommends it because it's oftened fanboyed and "SafeSonic", but there are so many other options for the price. Even the Corsair VS has a higher end protection chip.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/911159-planning-help/#findComment-11206311
