165-163=2mm space.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/910036-help-assap/#findComment-11179153
Well.. No, it's under the limit.
Also, I have noticed cases are kinda conservative with this number. My CPU cooler is 160mm tall and my case can take 160mm max.. Posed no problems with the build and fit for some mm to spare.
https://linustechtips.com/topic/910036-help-assap/#findComment-11179157
39 minutes ago, FloRolf said:
165-163=2mm space.
okay thanks, what do you guys think of this build? https://au.pcpartpicker.com/user/adzygamer15/saved/KPVvVn , also how many fans do i need to add to the case?
https://linustechtips.com/topic/910036-help-assap/#findComment-11179211
I would change the board to this
https://au.pcpartpicker.com/product/39hj4D/asrock-z370-pro4-atx-lga1151-motherboard-z370-pro4
also, i would fill the 2 fan slots, one each for the front and the back
but not necessary enough
"Make it future proof for some years at least, don't buy "only slightly better" stuff that gets outdated 1 year, that's throwing money away" @pipoawas
-Frequencies DON'T represent everything and in many cases that is true (referring to Individual CPU Clocks).
Mention me if you want to summon me sooner or later
My head on 2019 :
Note 10, S10, Samsung becomes Apple, Zen 2, 3700X, Renegade X lol
https://linustechtips.com/topic/910036-help-assap/#findComment-11179316
11 minutes ago, adzygamer15 said:
what's the different between this board with the z370-a prime? besides the price factor
SLI support, since i doubt that you would use it on the Z370-A
BIOS Interface, I think that AsRock isn't that far from Asus' Interface. Also the RGB sync will be hands down to Asus for the almost universal compatibility with other RGB devices
My head on 2019 :
https://linustechtips.com/topic/910036-help-assap/#findComment-11179343
