Just now, Austin243 said:
I have it on a USB but don't I have to get in the bios first for that
Then pust the key to get into the bios when you turn it on. How did you make this drive booatable.
Id also unplug your hdd when installing windows.
https://linustechtips.com/topic/907492-need-help-asap/#findComment-11154440
5 hours ago, Electronics Wizardy said:
Then you need to install a os first.
Thanks I got it
Ok I do need help I made it with the windows tool on the Microsoft website and if I have any internal drives it dosent work
https://linustechtips.com/topic/907492-need-help-asap/#findComment-11154442
So you can boot into the installer when you don't have any drives?
Then your boot order is wrong, go change it in the bios.
https://linustechtips.com/topic/907492-need-help-asap/#findComment-11154454
are you in the boot settings?
Is your usb drive plugged in?
It should show the usb, and just select that as your first boot device.
Yes I found the problem it was my USB connection wasn't reading anything bud USB 3.0
Sorry first build thanks you helped a lot
https://linustechtips.com/topic/907492-need-help-asap/#findComment-11154527
Well... Apparently you have Windows 10 S, in stead of Windows 10.. That only allows you to run Microsoft store apps. You need to install Windows 10 Home or Pro if you want to do stuff like download your drivers.
https://linustechtips.com/topic/907492-need-help-asap/#findComment-11154918
23 minutes ago, Austin243 said:
I have windows 10 but can't open anything I downloaded as steam of nividia drives nothing and it says windows 10 s only runs verified apps from the store
Just wipe your drive and reinstall with windows 10 home or pro, you don't need a key
You can also just turn off Windows 10 S, which never should have existed.
https://linustechtips.com/topic/907492-need-help-asap/#findComment-11154925
