What Cryptocurrency is best for Pi mining?
Solved by Windows7ge,
Only one I can think of off the top of my head might be Bytecoin but it has a value of 1/3rd of a penny. You could only pray its value increases substantially but a Pi CPU should be able to mine a few.
I don't see mining as being very profitable unless you just get lucky and the market value of what you mine goes up a lot. You could sell lemonade in your front yard for a month and probably make more than what your CPU/GPU can mine in the same time. Plus there's the degradation to consider. Just none of it is really worth it in my opinion unless you're good at trading on a market like WEX (previously BTC-e).
