I was initially planning on becoming a casual water cooling fan, but then I thought, why not let it consume my soul?
So i decap an old AMD Sempron that I had lying around and drill two holes for tubes, so I can ditch the waterblock and cool the silicon directly.
The mayor dissadvantage is that i can't use water.
I don't even remember if this processor works, so I use mostly to see if the system will leak when re-gluing the heat spreader and if the space under it is enought to pass a decent amount of liquid.
I might try it on a working processor later
https://linustechtips.com/topic/901601-diy-direct-chip-cooling/
Not much point. The liquid will have next to no area to actually pull heat away from the die. The only liquid that would work would be that 3M stuff that der8auer worked with.
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
https://linustechtips.com/topic/901601-diy-direct-chip-cooling/#findComment-11097085
I read this entire sentence in the wrong context. I was seriously about to ask you how you plan on turning yourself into a fan...
Anyway, this will barely work because there really isn't enough space for this to work unless you increased the surface area of the heat shield vertically by a significant amount. It would have to look something like an AIO pump does in order to benefit cooling the CPU.
"The only thing that matters right now is that you're here, and you're safe."
https://linustechtips.com/topic/901601-diy-direct-chip-cooling/#findComment-11097126
When you said Direct Chip cooling I thought you were going to put a water-block in direct contact with the die (something that may be rare but not unheard of).
Then I saw the photos and all I can think of is that this is a disaster waiting to happen.
https://linustechtips.com/topic/901601-diy-direct-chip-cooling/#findComment-11098343
