specs to run a 144hz 1080p monitor?
Shadowciaw
hey sorry if this doesnt belong here, im thinking of getting a 144hz 1080p display maybe sometime in the future, and im wondering if the minimum specs needed to run it are uh affordable?
im not doing any heavy gaming honestly, but hoping to run light games like osu? currently i have a i5 7200u laptop but im also thinking of getting a ryzen 5 1600 maybe in the future, and a graphics card depending if the prices come down enough for me. how much power would it take to hover around at least 120hz? what would the performance be if i only had a cpu trying to run it by itself?
thanks guys
id get a gtx1060
CPU: i7 8700 GPU: Asus ROG Strix GTX 1080 Mobo: Gigabyte Z370 Gaming 5 Ram: 16GB EVGA SuperSC SSD: Samsung 850 EVO 250GB
HDD: Seagate Barracuda 2TB PSU: TX650M Case: NZXT S340 Elite OS: Windows 10 Mouse: Logitech G403 Mouse Mat: HyperX Fury S Pro XL
Keyboard: CM Masterkeys Pro S (reds) Headphones: Sennheiser HD598 Monitor: Asus 24' MG248QR Devices: IPhone 11 Pro Max + 13' Macbook Pro
Basically you would want to purchase a discreet video card. I believe I read that the GTX 1050 and above would work wonders for what you want and also give you time to upgrade the other components. FYI basically any AM3+ or intel equivalent or better would be fine
PSU Tier Ranking List
Ryzen 5 1600x|ASROCK                      |16GB DDR4 3400Mhz Corsair Vengence   | (partial build in progress)
FX-8350 AM3+| ASUS M5A990FX V1 | 32GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 850 PRO | Win 7 64 Pro | EVGA 750W G PSU | EVGA 750 ti 6GB | Corsair H100i v1
FX-8120 AM3+| ASUS M5A990FX V2 | 16GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 850 PRO | Win 7 64 Pro | EVGA 750W G PSU | EVGA 750 ti 6GB | Corsair H80i v1
I5-2500K LGA  | ACER MOBO??         | 16GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 860 PRO | Win 10 64 Pro | EVGA 750W G PSU | EVGA 970 SC 4GB | Corsair H80i v1
For osu to run 144hz you don't really need much, an iGPU might even be enough if it supports 144hz. With my 1070 its getting 3000fps in osu so a 1050 would work fine or a 1060 for anything more than just osu like CSGO or overwatch.
3700x, Asus B450i, 16GB Corsair Vengeance RGB, Gigabyte GTX 970 ITXDan A4-SFX, SX600-G, 120mm AIO.
Don't forget the TI models. I personally find they run everything better and if you do get a Video Card make sure you get it with minimum 3Gb DDR4/5
33 minutes ago, Shadowciaw said:
Your CPU is the bottleneck for refresh rates
your GPU is the bottleneck for resolution/quality settings
Depending on the game even a GT 1030 will be enough, or a Ryzen APU, like esports titles will run that fast on that lower end hardware
What's the budget for your future desktop? And monitor?
ah okay okay ty!
desktop i hope is 1500 CAD including monitor. not really in a rush to buy anything tho! been looking at the ryzen 5 1600, but is the 2400g just as good?
5 minutes ago, Shadowciaw said:
ah okay okay ty!
It has less cores, but for the most part will work fine even with higher end GPUs in the future
The main point of the APU is that it gives you pretty alright 1080p gaming while there are no real GPU options. Better off saving your money for  the future releases like the Vega refresh and GTX 2080, which is overkill for 1080p 144hz though, you only need like a Vega 56 or 1070 tier performance for that resolution/refresh rate in AAA games
Could potentially use an SSD, better case, and better PSU, and a cheap tower cooler to do  better than the stock cooling. RAM pricing and GPU pricing sucks right now.
PCPartPicker part list: https://ca.pcpartpicker.com/list/2Cg7YT
Price breakdown by merchant: https://ca.pcpartpicker.com/list/2Cg7YT/by_merchant/
CPU: AMD - Ryzen 5 2400G 3.6GHz Quad-Core Processor  ($209.99 @ Memory Express)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  ($110.50 @ Vuugo)
Memory: ADATA - 8GB (2 x 4GB) DDR4-3200 Memory  ($102.99 @ PC-Canada)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.00 @ Mike's Computer Shop)
Case: Rosewill - FBM-X1 MicroATX Mini Tower Case  ($29.99 @ Newegg Canada)
Power Supply: Cooler Master - MasterWatt 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($65.99 @ Amazon Canada)
Monitor: AOC - G2460PF 24.0" 1920x1080 144Hz Monitor  ($265.14 @ Amazon Canada)
Total: $833.60
Generated by PCPartPicker 2018-02-16 00:46 EST-0500
There's how the APU will scale with a higher end GPU, it's basically an R5 1400
